what size wrench do i need for the stock manifold bolts
Old 06-12-2006, 07:13 PM
z28_n_tx's Avatar
Default what size wrench do i need for the stock manifold bolts
(LT install)did a search , no luck...its my first install so bare with me guys.. i need to know the size wrench i need to remove the stock bolts. and how in the world did you guys remove the last bolts?? i dont see how im going to get anything back there..
Old 06-12-2006, 07:15 PM
Luna's Avatar
its a 10mm, remove the coilpacks to get to the back ones and its cake
Old 06-12-2006, 07:34 PM
z28_n_tx's Avatar
is it as easy as it sounds?? i dont want to screw something up byt taking it apart and not knowing what the heck im doing or putting it back together wrong..
Old 06-12-2006, 07:51 PM
Luna's Avatar
I would use some penetrating oil on the bolts (blaster kicks ***) so they don't break. But yea, take the coil packs off if its a 99+ they come off all in one bracket and they are really easy to take off / put on.
You can IM me if you have any questions about the install
Old 06-12-2006, 08:19 PM
2K2WS6TA's Avatar
10mm gear wrench, for the pass back, get from under the car, the drivers back use a short socket with a 1 inch extension
Spray bolts with PB Blaster, and allow to soak for a couple of hours
I left the coil packs on during my install
Old 06-12-2006, 08:58 PM
Mssingkid's Avatar
It's pretty easy.. do it with a friend and you should have it done in a few hours..I did it this past weekend seems alot harder than it is..
z28_n_tx's Avatar
can i get the blaster at auto zone or walmart? thanks guys ..ill be going solo tomorrow, so i might have other q's throughout the day..
Old 06-12-2006, 09:18 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
either place I bet....all the shops have some make/brand of the stuff..
Old 06-12-2006, 11:01 PM
That's what she said...
TheBlurLS1's Avatar
Go out an buy a 1/4" drive air ratchet. I can remove ALL my header bolts with mine. You can damn near change the sparkplugs through the tailpipes with that bitch.
I like to take the valve covers off to do the passenger side, but that's just me.
Old 06-12-2006, 11:16 PM
Grimes's Avatar
mommy said to never play with air tools
just make sure that socket is on there right before you pull the trigger, i'd hate to see a "stripped header bolt" thread
Old 06-12-2006, 11:32 PM
TheBlurLS1's Avatar
The 1/4" impact doesn't have enough torque to mess anything up too bad. You can use it as a wrench to break the bolts loose, then squeeze the trigger to zip it out.
I got pissed off at some heat shields one night that I was trying to remove, so I got out my 1/2" drive impact (rated for 90psi, but I run it at 150psi ), I put on a 1/2" - 3/8" reducer, then a 3/8" - 1/4" reducer, then a 7mm socket lol.
I stuck it on the bolt, hit the trigger, the 7mm socket flew off so fast that we never saw the bitch again.
........ screw came out though...........
Old 06-13-2006, 06:47 AM
Mssingkid's Avatar
Old 06-13-2006, 09:53 AM
under pressure's Avatar
Don't forget to have a little fun too. Isn't that a large part of the reason we spend so much money on these things?
Old 06-13-2006, 03:14 PM
SRpwred240's Avatar
do you guys anti-seize the header bolts if so which antiseize do you use?
Old 06-13-2006, 03:27 PM
xaon's Avatar
i antiseize mine... kind does not matter. It is just a protective barrier to keep the steel and aluminum from corroding against oneanother
Old 06-13-2006, 04:11 PM
2K2WS6TA's Avatar
I used the permatex, anti sieze, cause that's what the local store stocked. It really doesn't matter the brand, just that you use it
Old 06-13-2006, 04:25 PM
SRpwred240's Avatar
yeah Im gonna use some anti but isnt there a medium (blue) strength and high (red) strength. or maybe Im thinking oof something else?
Old 06-13-2006, 05:02 PM
Luna's Avatar
I think you are thinking of loctite? I don't think you want to loctite them
Old 06-13-2006, 05:06 PM
TheBlurLS1's Avatar
Definatly don't use Loctite or "thread lock" of any kind. Anti-sieze is the opposite of that.
Confucius say "Easier to re-tighten than re-tap...."
Old 06-13-2006, 05:10 PM
Moderator
davered00ss's Avatar
8 or 10 mm, I used a gear wrench and 1/4 socket wrench.
