Spark plug help fast!
Old 06-16-2006, 01:08 PM
Z28LS1KID's Avatar
Default Spark plug help fast!
Hey guys I'm in the middle of the LT install and pressed for time (getting dyno tuned tomorrow). I wasn't planning on doing plugs, but I figured why not. The car had Denso Iridiums and was running great, but I can't find them anywhere. Are Ac Delco Iridiums good to use? I know they cost $7 each but I don't care as long as they are good plugs and will last me a while. And what should they be gapped at? Thanks guys.
Old 06-16-2006, 01:18 PM
brad8266's Avatar
AC Delcos are fine. Gap around .055 I believe.
Old 06-16-2006, 01:21 PM
HandsomeBWouderful's Avatar
I second this. If you can find some NGKs, those are good too.
Old 06-16-2006, 01:30 PM
Z28LS1KID's Avatar
So the AC Delco's are good to use, good to hear. And .055 was what they were gapped at when I took them out, just needed to double check. Thanks again.
Old 06-16-2006, 02:57 PM
SLO98Z's Avatar
Do not gap the iridium plugs. You could possibly break the iridium electode. They should be "just right", out of the box.
Old 06-16-2006, 03:07 PM
99FormulaM6's Avatar
Ngk Tr55
Old 06-16-2006, 03:35 PM
That's what she said...
TheBlurLS1's Avatar
I just put a set of NGK TR-55IX's (iridium) in my car and noticed no difference from the NGK TR-55's, runs great with either.
Old 06-16-2006, 03:47 PM
only diff is the price
Old 06-16-2006, 04:01 PM
SLO98Z's Avatar
The iridiums last longer and require less juice
Old 06-17-2006, 04:14 PM
FormulaNHRA's Avatar
most people get the ngk v-power's which is a copper plug, but ngk also sells platinum that runs around the same price as the iridiums. Myself, i got the ac delco just to keep everything the american muscle way.
Old 06-17-2006, 08:54 PM
SSU, come over and relax
skywalkrNCSU's Avatar
id stick to the copper ones....not worth the price for the others imo
Old 07-11-2006, 11:38 AM
TA BOY's Avatar
not try to hi-jack, i got a 98 ta with a ls2 6.0 with heads and cam. what should i gap them at. (the ac delcos IRIDIUM)
Old 07-11-2006, 05:24 PM
dalejr8ls1's Avatar
I went with the iridiums..no problems at all
