Passanger Header Install Question
I have half of my header install done and decided to call it a night, before packing up i tried a quick fit up of the passanger header from below and it seemed stuck.
Is it possible to drop the LT in from the top if I remove the passanger side valve cover?
I thought in one of my searches I read this, but not sure
Anyone?
Thanks
Anyone?
Thanks
I never pulled out my spark plugs but if your doing this off jack stands which i assume you are you need to lift the car up really damn high to get the header in. I mean really damn high. You have to put it up in there at a sharp angle. If your still having problems give me a call. I've PM'd you the number
How do you notice if the car run like "death"? I didn't took my plugs out when I installed 2 days ago, and I don't think it run good enough.
Would it run on 7 cyls if one plug even is half-broken?
That's what she said...
Some people crack them just putting new plugs in, by hitting them with the socket and what not.
Originally Posted by TheBlurLS1
You will get popping at backfiring from the unburnt fuel lighting off in the collector. The cracked insulation on the plug will allow the spark to ground out on the head before it gets to the combustion chamber.
Backfireing all the time? I get in just some times when WOT, guess it's just running rich.
The car runs well, but it's just ticking and rasping on cold start to go off when hot.
