To Descreen the MAF or not to descreen the MAF..that is the question
Well....what do you guys think? I bought a new book titled, "How to build High-Performance Chevy LS1/LS6 V-8s". By Will Hanzell he says he got a lot of his info from Ed Koerner. In the book it says to descreen the MAF and even tells you the easiest way to do it. What do you guys think? What are the cons of doing this? Because according to this book, there aern't any, just gains in horsepower.
My tuner de-screened mine while on the dyno, he said as long as you compensate for it in the tuning you're fine. Is it really worth it? Not sure, we saw a little gain, but he was adjusting a few things at the same time.
I would probably just leave it alone.
i wouldn't have descreened it either cause i just recently had my car in gm for a ses light on and they said it was blowing because of my modifications to the mass airflow sensor but it was really blowing because my catalytic converts where out
When i installed mine, i noticed a huge front end difference, BUT,,i installed my K&N, Lid, CIA, SB, and MAF all at the same time, along with all TB mods at the same time as well, so hard for me to tell you that just the 85MM MAF that made the diff all on its lonesome.
Originally Posted by The Rookie
ok... I will leave it alone. are there any positives to changing to an aftermarket one?
Tech Resident
actually your stock maf is good to 500 hp, not 400. do you plan to be making over ~430rwhp? if you don't, you'll never need to change your maf...ever.
think of it like this: ever hear of reports of dirt or buildup in someone's maf screen? that's a common problem for throwing codes - a dirty maf screen. that means that your maf screen stops some large particles from entering your intake manifold. those large particles would be in your engine if it wasn't for your maf.
don't so much as TOUCH the stock maf. it keeps your engine running better and helps keep it cleaner in some cases. stock maf FTW.
