how good is the moble oil filter
Old 09-01-2006, 10:05 AM
TRANSAM_2000's Avatar
Default how good is the moble oil filter
Is it a good filter. Anyone with some info on it.
Old 09-01-2006, 10:06 AM
sickws698's Avatar
ive heard goodthings, never used it myself tho
Old 09-01-2006, 10:11 AM
nexvctm2001ss's Avatar
It's the only kind I will use
i just changed my oil and put it on i was using the ACdelco.
Old 09-01-2006, 10:32 AM
oange ss's Avatar
AC Delco > Mobil filters
Old 09-01-2006, 11:09 AM
which is better moble 1 filter or ACdelco
Old 09-01-2006, 11:31 AM
oange ss's Avatar
Delco
oange ss's Avatar
or Napa/Wiix
Old 09-01-2006, 12:05 PM
WhiteRhino's Avatar
I''ve ran the mobile for a while. From what I've read the K&N is also another great filter to use. Check out bobstheoilguy.com. Tons of great info there. I've been running the K&N #2006 for a few years. It's the longer truck filter. It also has a nut made into the bottom of the filter, so it's a sinch to change.
The K&N is similiar to the Napa gold or wix. I do believe they go into bypass mode sooner as well, while flowing more oil. So your engine doesn't starve for oil when running wot.
Old 09-01-2006, 12:28 PM
I just cant see myself paying $12 for a filter i guess its worth it.
Old 09-01-2006, 01:01 PM
BigDaddyBry's Avatar
Mobil 1 is great, especially when Autozone has the buy 5 qts of oil get an M1 oil filter free.
Old 09-01-2006, 01:24 PM
cjels1's Avatar
wix and or acdelco.
DONT USE FRAM! THEY ARE STRAIGHT UP PAPER ON THE INSIDE
Old 09-01-2006, 07:39 PM
joecar's Avatar
The M1 filter has thicker sheet metal, you can't dimple the side with your grip
(I have dimpled a few AC Delco by squeezing in my hand).
I cut mine open and spread out the filter material, it's about twice as long.
The threaded flange is much thicker, with more turns of thread.
The drainback valve is better and better located.
The o-ring/gasket is very thick and securely embedded.
The M1 weighs more than most other filters.
It is very well made.
Old 09-01-2006, 07:41 PM
joecar's Avatar
Yes, that's what I get.
Old 09-01-2006, 07:44 PM
The PAT WS6's Avatar
i usually always use mobil one its like 10 bucks tho.. i tryed the fram now and it works fine. i guess i have blown up the motor wit it yet.
Old 09-01-2006, 07:49 PM
00pewterWS6TA's Avatar
