GM LS6 VS Holley Aluminum LS1
Old 09-01-2006, 12:06 PM
Mohammed's Avatar
Default GM LS6 VS Holley Aluminum LS1
I found 100$ difference between both of the manifolds.. which one worth buying ??
GM 500$
Holly 400$
Old 09-01-2006, 12:15 PM
Hugger's Avatar
Whatever you do don't pay $500 for an LS6 intake. You can find them for sale all the time for $300. That seems to be about the going rate lately. Most people are probably going to tell you that the LS6 is a better intake since it is made of Nylon 66 and won't heatsoak like the Holley metal intake.
sdbrown84's Avatar
I have heard there is little to no difference. I just went with the LS6 and called it a day.
Old 09-01-2006, 12:19 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
GM 500$
Holly 400$
two words for you, "heat soak"
Old 09-01-2006, 12:23 PM
Mohammed's Avatar
you mean to forget about the holley !!!
Old 09-01-2006, 04:19 PM
redtail2426's Avatar
forget about any metal intake for the ls1 unless your running twin turbos spitting out more then 25lbs boost .The dupont nylon 66 material is far lighter,and runs much cooler..
Old 09-01-2006, 07:42 PM
The PAT WS6's Avatar
i would deff go wit the ls6 setup my self, i could feel a difference when i put mine on
Old 09-01-2006, 08:34 PM
~JOSHUA's Avatar
I had an LS6 only my 2002 before I went for the polished look.
I gained some midrange with the Weiand, without losing any up top. Now it's twin turbo'd.
Heat soak in reality is bs. On a 500hp car you might lose 3. Think about the volume of air flowing through the runners, do you think it has time to heat to any noticable amount?
Old 09-01-2006, 09:22 PM
1fastz's Avatar
yup...heatsoak is bs
Old 09-01-2006, 10:30 PM
An intake charge may heat 10 to 15 degrees more then with the nylon intake,and it just makes your car more prone to KR.I just dont think its worth it unless your going for a chromed engine look like firehawk,which i must say is badass and worth every penny.
Old 09-01-2006, 10:35 PM
98SS1LWEE's Avatar
The fastest M6, naturally aspirated car, just so happens to have an aluminum intake.... And it whooped up on a 69 Firebird too ! ! !
Old 09-01-2006, 10:59 PM
nokeman's Avatar
Id go LS6 unless you are trying to go with a themed polished/chromed look
Old 09-01-2006, 11:58 PM
01FormulaTA's Avatar
id go w/ the holley, power will be about the same, you will save $100 and well it'll look cooler lol
Old 09-02-2006, 06:02 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Just get the LS1 off there and you will be beyond improvement.
Old 09-02-2006, 07:22 AM
Benjamin Russick's Avatar
I see LS6s for sale in the $300-325 range all the time. They weigh less and flow the same.
Old 09-02-2006, 08:22 AM
Mohammed's Avatar
where do you see them !! if it's online..just give me the link ...
well most voted for the ls6.... I think I won't hesitate to get it ..
thanks anyway
Old 09-02-2006, 09:56 AM
85ta383's Avatar
lol not to be a smarta@# buuuuuuutttttttt https://ls1tech.com/forums/lsx-parts-sale-45/
ok so a little smarta@#
later aaron
Old 09-02-2006, 11:06 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
LS6 intake gets my vote.
Old 09-02-2006, 11:28 AM
staringback05's Avatar
ls6, and pay 350 shipped not 500 geez
Old 09-02-2006, 05:56 PM
WILWAXU's Avatar
Heat soak is only a joke if you do not race your car. If you spend time drag racing you can see signifigant difference in the intakes at the track.
