Cutout (I pipe Vs Borla)
I'm looking to purchase an electric cutout. I just put on a catted y pipe and I love the sound it makes with no rasp but it made my car a LOT quieter. I wanted a setup where I could make my car louder on demand and i'd like your opinions. Should I place a cutout directly after the y pipee joins or should I put it on my adjustable borla? How different will the noise level be? Would the cutout even be worth the extra sound if its that far down the exhaust? Will I lose ground clearance?
ok correct me if im wrong so I can help ya out. the borla has the plates, and I do beleive you can run the wide open plate so its not restricted and very similar to a straight-through design correct?
If you do have the open plate I really dont see a cutout adding much hp sicne the brola already would be flowing great. But you may get a few ponies, like 5 and you can put the cutout under the rear seats. GM amde a perfect little spot for it back there
Would the cutout by the rear seats add a lot of volume?
right I know where the cutout is, jsut wasnt sure if it bypasses the muffler all together or not. Its gonna be a little louder behind the rear seats simply because nothing will go through the cat-backa t that point and less distance to travel and the dump will be closer. unless you can get it in front of your cats its not gonna be THAT much louder
