Who ports manifolds?
Old 11-13-2006, 08:23 PM
Dave88z's Avatar
Default Who ports manifolds?
Tried the search (broken), just wanted to know who to go to for a port job on my victor jr manifold. I don't know how this should be done since the block is decked and that changes the alignment. Will they just gasket match, or do they need port measurements from my heads? Let me know about your experiences and the best way to do it.
Old 11-13-2006, 09:01 PM
Dave88z's Avatar
Oh yeah, what should I expect to pay for it
Old 11-13-2006, 09:08 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I know Tony Mamo @ AFR ports a mean FAST manifold. Not sure about the carbed ones. Never hurts to ask.
Old 11-29-2006, 09:00 PM
Dave88z's Avatar
Anyone? I have seen pics of an ETP ported victor jr. I think they charge about
1700.00. Does this sound right?
Old 11-29-2006, 10:27 PM
68birdls1's Avatar
no that is not right, i had heads ported for $600 and i had my intake port matched to that in that price. so no i would venture to say no more than $300 depending on who and where
Old 11-29-2006, 10:37 PM
SHAKER's Avatar
You are looking at $400.00 plus s/h. That includes top to bottom gasket matched and all and not to mention a free glass beading if it needs it. You send in the gasket YOU ARE GOING TO USE and the intake. Keep in mind that in order to do it correctly it should be gasket matched to the heads for the best job. Call metco motorsports and ask for brian
864 332 5929
Old 11-30-2006, 09:28 AM
That's what she said...
TheBlurLS1's Avatar
864 332 5929
Intake gaskets? We aren't building a big block. We use o-rings that have machined grooves which sit back from the edge of the port.
I would have them port matched to your heads, after the heads are bolted onto the motor if possible. I know you can use an inside scribe on a FAST, not sure how you'd go about marking the outline of the ports on a Victor.
Old 11-30-2006, 09:33 AM
ls1408cp's Avatar
I know mine was decked alot to get it to line up.
Old 11-30-2006, 05:51 PM
Dave88z's Avatar
Has anyone tried Extrude Honing? I guess I need to get the heads bolted down and see whats going on. I just hate lugging the motor back and forth to the machine shop.
Old 11-30-2006, 11:35 PM
SHAKER's Avatar
well the last 20 or so victor jr. intakes i have done were all used with a gasket on either sm or big blocks. it wasnt specified what it was going on so my bad but if the o ring is what he was shooting for. either way if you need to know how to properly port match the intake to the heads. you can do it in your garage on a stand and go from there. using a scribe is not the way to get correct results. you will need the heads installed and whatever gaskest you are running and the intake. a 24 inch straight edge and a small square. a sharpi and a scratch all. you need to transfer the openings of the ports over to the intake. if you need more info let me know. it is easier than it sounds. shakerheads@aol.com
Old 11-30-2006, 11:47 PM
TheBlurLS1's Avatar
Wow! I just re-read my post and I sounded like a douchebag. Sorry about that.
I've always wondered how the hell they figure out how to port match the intakes.
Old 12-01-2006, 12:45 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Casey =
Old 12-01-2006, 12:48 AM
RrCoX22's Avatar
lol
...those shoulders are looking a little feminine Casey
Old 12-01-2006, 01:02 AM
TheBlurLS1's Avatar
Originally Posted by orangeapeel
Sad but true.
Damn I hope that face is photochopped onto that box. Don't know where that guy is going to stick the douche at. Holy ****.
Old 12-01-2006, 01:07 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Yeah. that is a harsh looking chick.
Old 12-01-2006, 01:30 AM
TheBlurLS1's Avatar
Looks like someone set her face on fire and put it out with a hatchet.....
Old 12-01-2006, 02:45 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
And then sprayed that remaining douche water on it.
Old 12-01-2006, 07:08 PM
Specialized's Avatar
Thats my girlfriend..
Kidding.
Old 12-02-2006, 04:17 PM
Dave88z's Avatar
Thanks for the help guys.
j/k
Quick Reply: Who ports manifolds?
