Bolt Ons: What to expect to spend?
Old 11-20-2006, 11:20 PM
nomorews6's Avatar
Default Bolt Ons: What to expect to spend?
If I am taking a completely bone stock ls1 based f body with the intention of having it run 11's stock internally, n/a, what can I expect to pay?
Old 11-21-2006, 01:22 AM
Beasst8's Avatar
Well, you can spend anywhere between 350-950 for a catback/or TD setup.
You can spend from 350-1500 for some long tube headers.
150 for lid and filter. (just a guess, dont know what lids are going for these days)
1200 for 90/90 setup
M6 or A4. If A4 upgrade stall.
2300 ish for a new rear-end
Then some sticky tires and weight reduction.
Thats just things that are not internal engine. But can get pricey.
I know that there are 11 sec cars that didnt spend near that.
you can spray and call it a day.
Just my .02
Old 11-21-2006, 01:24 AM
Beasst8's Avatar
Oh or as far as the exhaust you can just spend 45 bucks on a cutout in your stock I pipe. Done
Old 11-21-2006, 02:04 AM
nomorews6's Avatar
waht is the hp difference between a cut out at the stock i pip vs. the other exhaust configurrations?
Old 11-21-2006, 02:47 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
There are so many options, I don't know where to tell you to start honestly.
Old 11-21-2006, 02:24 PM
silverbandit0996's Avatar
giggle juice!
Old 11-21-2006, 02:25 PM
nomorews6's Avatar
spray will be there too for sure
Old 11-21-2006, 02:34 PM
TOS98SS's Avatar
A cut out sounds like garbage (IMO) and will get you a few more ponies the cat back sounds better
Old 11-22-2006, 06:51 AM
jam01's Avatar
why not try a magna charger and exhaust. i think youll have more usable power, than nitros. also easier to tune with.
Old 11-22-2006, 09:18 AM
nomorews6's Avatar
magnacharger? probably because that'd be more expensive I'd imagine
Old 11-22-2006, 11:08 AM
300bhp/ton's Avatar
If 11's are you're only goal and you have a A4 then a STALL is a must (3600+) add some sticky tyres (MT DR's 255/50R16).
The stock 10 bolt will probably be ok for a bit as long as you don't beat on it too hard (burn outs/do-nuts and wheel hop).
Then start too look at power such as LT's and exhaust, lid maybe a pulley, ported TB. 11's should be easy but it will mostly be down to the 60'.
Old 11-22-2006, 12:59 PM
luxexpress1's Avatar
To run in the 11's, bolt on only, you will also have to reduce as much weight as you can live with and focus on your suspension. Dump the front sway bar, relocation brackets and new lower control arms, aftermarket torque arm, etc. to make sure you get your 60' times in the 1.5x range. That with full bolt ons and good air will get you very close to the 11 second time slip you are looking for. Also, you will likely have to play with your shift points, timing and fuel to get there. A good programer should be at the top of your shopping list. Good luck.
Old 11-22-2006, 01:17 PM
nomorews6's Avatar
i'm going to make it harder on me and try it with a convertible possible at all?
Old 11-22-2006, 07:01 PM
evrae205's Avatar
full boltons. if a pre 01 car get ls6 intake and 28lb injectors, a big stall and some ET streets. and if that dont get you there spray it.
One of my friends has a 02ss with slp loudmouth,ported TB and lid, stall and ET streets and rusn 12.3s consistantly. Im sure with headers, ory,udp,and ewp you could get damn close to high 11s
Oh and P.S. spend some serious cheese on suspension of course.
nad of course if you cam it or spray it youll be 11s pretty easy.
Old 11-22-2006, 07:08 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I love wheel hop!
Old 11-22-2006, 07:13 PM
nokeman's Avatar
haha...
Old 11-22-2006, 07:17 PM
landstuhltaylor's Avatar
^^^youre nuts
Old 11-23-2006, 04:20 AM
300bhp/ton's Avatar
It's possible to go faster for less.
I know someone who went 11.63@117mph with only exhaust/lid, 3.42's (auto), stall sticky tyres different rockers (only internal part) and a few suspension mods but nothing too wild. UNTUNED.
I think they also used some ballast in the boot/trunk (a few bags of sand) to promote a bit more off the line traction.
