TR ported TB worth 2rwhp
Old Oct 24, 2006 | 09:25 PM
RealLiveMD's Avatar
Default TR ported TB worth 2rwhp
Just thought I should post I went from 404 to 406 corrected on the dyno.
Old Oct 24, 2006 | 09:30 PM
Tainted's Avatar
lol .002 off your 1/4!
Old Oct 24, 2006 | 10:08 PM
02gixxersix's Avatar
I could swear mine was more than that although I dont have the dyno numbers to prove it.
Old Oct 24, 2006 | 10:35 PM
Starz T/A 17's Avatar
damm, I coulda swore mine was worth more then that, and it gave me better throtle response. What other mods did you have?
Old Oct 24, 2006 | 10:38 PM
TORCHD 02 TA's Avatar
everyone was saying in my thread it is worth ~10 rwhp
https://ls1tech.com/forums/generation-iii-external-engine/596558-p-p-tb-worth.html
Old Oct 24, 2006 | 10:41 PM
Louie83's Avatar
Someone posted a graph before showing a 8rwhp gain.
Old Oct 24, 2006 | 10:54 PM
ChocoTaco369's Avatar
Tech Resident
dynos lie. is your A/F ratio the same on both dyno runs? what about the temperature? what about the humidity?
i'd be willing to bet either your A/F ratio is less ideal, or you dynoed the 404 on a much cooler day than the 406. don't forget, a 10 degree drop in temperature is worth 1% horsepower. since you're dynoing at ~400rwhp, you should have over 450 hp at the crank. if you dynoed on a day 20 degrees hotter, that's a 2% or 9rwhp difference on the dyno. that means your ported throttle body is actually worth 11rwhp with the hypothetical temperature difference factored in.
your ported throttle body is NOT worth 2rwhp. it's worth several times that. what you have is the temperature and A/F ratio making your dyno numbers lie.
Old Oct 25, 2006 | 12:08 AM
Hawk108's Avatar
^^^ +1, Unless the dyno's were done on the same day then im gonna say that you got more then 2 rwhp from it.
Old Oct 25, 2006 | 01:14 AM
chrs1313's Avatar
about 5rwhp worth the 75 bucks, good bang for your buck
Old Oct 25, 2006 | 01:18 AM
staringback05's Avatar
it all depends on what you have it hooked up with also....with a ported tb on a stock ls1 manifold it wont show as much gain as with a ls6....
Old Oct 25, 2006 | 03:22 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
https://ls1tech.com/forums/showthread.php?t=596558
Lol, I think I did, but I have seen it make close to 10 on a cammed car.
Old Oct 25, 2006 | 07:19 AM
ahhh i see.. but still even if it is ~6 rwhp it will be worth it. i am gonna have Bo Whtie P&P mine
Old Oct 25, 2006 | 09:05 AM
INMY01TA's Avatar
Just got a TR ported tb. Still waitiing on my core refund.
Old Oct 25, 2006 | 10:15 AM
RealLiveMD's Avatar
It was a cooler day and I made 411 but my tuner said that when he "corrected it" (some math formula to allow dynoes to be about equal on different days) it was 406 up from 404.... and yes I have an ls6 intake.
Old Oct 25, 2006 | 10:25 AM
TWS's Avatar
TWS
Did somebody already post: THAT'S WHAT CORRECTION FACTORS ARE FOR!
No two dynos, especially on different days, or even the same dyno on different days... is going to deliver the exact same readings. I'm not saying that. But correction factors are going to make things close enough for valid comparisons. When a minor tweak, like P&P a TB, it's going to be hard to tell what it gained because you are talking about just a handfull of RWHP anyway.
Old Oct 25, 2006 | 11:38 AM
Louie83's Avatar
Graph showing 8 hp/ 6 tq
https://ls1tech.com/forums/showthrea...ight=ported+tb
7.5 hp gain on a bone stock car
https://ls1tech.com/forums/showpost....3&postcount=20
Graph of a stock car with Bo White - gained 8hp / 7tq
https://ls1tech.com/forums/showthrea...orted+tb+gains
Old Oct 25, 2006 | 01:15 PM
99 bad aSS's Avatar
who gives a crap how much power it gives you, as long as it helps drop a .1 or gain a MPH is what really matters.
Old Oct 25, 2006 | 01:30 PM
i am going to have Bo P&P my TB
Old Oct 25, 2006 | 03:00 PM
Cop Car's Avatar
more proof that it is a waste of time.
if you need more throttle body go to 90mm
Old Oct 25, 2006 | 03:25 PM
Tech Resident
ported TB a waste of time. let's all forget about the many, many graphs showing ~8rwhp gains, let's forget about the proven track results, let's forget all about the increased throttle response. we'll remember this one erroneous post with a dyno graph likely plagued with error due to temperature and A/F ratio being off.
that was a good joke.
