Installing Electric Cutout
Old 11-21-2006, 11:45 PM
LS1BlackBird99's Avatar
Default Installing Electric Cutout
I just had a SS cutout welded on the car and I'm ready to install the QTP electric cutout. Any suggestions for the install? What is the best way to go from the cutout to getting the switch inside the car and where to mount it?
Old 11-21-2006, 11:47 PM
Tainted's Avatar
mount it in the ash tray
Old 11-21-2006, 11:59 PM
What's the best way to get it inside the car from the exhaust?
Old 11-22-2006, 12:00 AM
Snuffles's Avatar
Where is the cutout installed on the exhaust?
Old 11-22-2006, 12:16 AM
miamifan3413's Avatar
For god's sake's:
https://ls1tech.com/forums/showthrea...ht=cutout+pics
Search is ur friend....there has been a million threads on this
Old 11-22-2006, 12:20 AM
Snuffles's Avatar
Originally Posted by miamifan3413
For god's sake's:
I was asking where the cutout was on his car.
And I think I *might* know where a cutout can be installed on a car.
Check post #2 in the thread you posted.
Old 11-22-2006, 12:58 AM
Tainted's Avatar
under the rear seat and go through the plug under the carpet, then run it under the carpet and intot he ash tray tada
Old 11-22-2006, 02:13 AM
Justin00SS's Avatar
How hard is it to mount the electric cutout to the regular cutout?
Old 11-22-2006, 12:45 PM
I apoligize.....I misunderstood the question, it's just that these threads r all over the place
Old 11-22-2006, 12:48 PM
It should fit right on the the bolts on the CO, it's not hard at all
Old 11-22-2006, 12:49 PM
I installed it right in the hump under the passenger side. So just go through a drainplug and under the carpet? What's the easiest way to approach getting it under the carpet to the ashtray without having to remove a lot of stuff?
Old 11-23-2006, 08:11 PM
Ar0ck's Avatar
You can loosen your centerconsole a little bit, and slide the I-wire through and snake it up into your ashtray.
Old 11-23-2006, 09:14 PM
Snuffles's Avatar
I can see how you took my post the way you did, I probably look like a noob with less than 100 posts.
And I must agree, there are tons of threads on this subject.
That's how I routed my cutout, through that rubber plug.
Two bolts will get your backseat out (takes 5 minutes) and pull up the carpet to access that little black plug.
Then straighten a metal coat hanger and snake that through the console, under the carpet and into the backseat to get the wire there.
Tape the I-wire to that and pull it through to the console.
My cutout switch is located next to my power seat controls, but I used the same process.
Quick Reply: Installing Electric Cutout
