Do I need the ALT UD pulley on an M6?
Old 12-10-2006, 01:02 AM
bayer-z28's Avatar
Default Do I need the ALT UD pulley on an M6?
I'm getting the UD ASP Crank pulley soon. I've heard that the A4's have charging problems w/o the ALT UD pulley. And what I got from the search, the ALT pulley negates the gains from the UD crank pulley. Is that true?
The ASP pulley kit w/ the ALT pulley is only like $15 extra anyway.
I tried a search too... not much on M6 ALP pulley recommendations.
Old 12-10-2006, 01:23 AM
BriancWS6's Avatar
I am not positive about the ASP, but I have ran the March UD on an A4 car and also one on my current M6 without the use of an overdrive alternator pulley without any issues.
Old 12-10-2006, 05:31 AM
00T\A's Avatar
Don't waste your money on an alt ud pulley.
The reduction in charging out weighs the gain in hp.
Which is not much anyway
Old 12-10-2006, 11:58 AM
staringback05's Avatar
it would be a good investment, not so much for the power gains but more or less that it will put less strain on your alt.....last time i checked a little pulley was cheaper then a new alt...
Old 12-10-2006, 01:50 PM
That's what she said...
TheBlurLS1's Avatar
I believe he wants to run an OVERDRIVE alternator pulley with his UNDERDRIVE crank pulley to avoid charging issues.
I have no problems with just an ASP underdrive pulley. I've read tons of posts where people have zero problems as well. You don't have 4 12's in the back do you?
If it ever does become an issue, you can change alternator pulley out at a later time.
Old 12-10-2006, 01:58 PM
bayer-z28's Avatar
ok, kewl. I have 2 12's, tho...
And yes, OVERdrive pulley for the alt and an UNDERdrive pulley for the crank. I suppose I can just get the dual pulley kit for $20 extra.
Old 12-10-2006, 05:15 PM
Grimes's Avatar
I have only the ASP underdrive pulley, and a couple of amps and a sub - no problems for the last year or so!
Old 12-10-2006, 05:24 PM
JonB's Avatar
I've been fine without the alt pulley for over a year now.
