Popping sound after open headers
Old 12-31-2006, 09:18 PM
m1candelaa1's Avatar
Default Popping sound after open headers
I just put on my Lt headers,open, going for custom dual.There is a poppin sound sort of like a hissing sound when i rev it sounds like its back firing.I chacked all my plugs and wires there all newis this normal?Do i need thicker wires?
Old 01-01-2007, 08:56 AM
LILWS6's Avatar
thats normal your gana hear every noise your car always made but theres was too many things in the way that you couldn't hear them. Well yea its normals if your running open headers
Old 01-01-2007, 09:23 AM
senicalj4579's Avatar
i think that has to do with unburned gas making it down the headers? i have the same thing sometimes
Old 01-01-2007, 09:38 AM
nor-texLS1's Avatar
yup, totally normal
Old 01-01-2007, 10:12 AM
Hennytime's Avatar
running rich + no cats
Old 01-02-2007, 05:21 PM
I had a custom dual exhaust installed today,the popping sounds like backfiring.In 6th gear 70 when i press the gas to speed up all it does is shake and starts poppin.Any idea whats goin on?
Old 01-02-2007, 05:22 PM
3.4camaro's Avatar
its under load at a low rpm, under the torque band. downshift if you want to accelerate in 6th.
Old 01-02-2007, 10:46 PM
any one
Old 01-02-2007, 10:48 PM
This started happening with recent header install. BTW 70 mph in 6th should not boggle(only under 60)
Old 01-03-2007, 02:16 AM
bww3588's Avatar
you got a misfire. check to see that none of your plug wires are resting on your headers. if so change them out with new ones or MSD. your choice. also you may want to install new plugs while your at it.
Old 01-03-2007, 09:09 AM
FU_I_AM_UltraZ's Avatar
that's the noises your muffler would soften up. on cold start ups with a completely stock M6 car, you can hear that pooping very slightly until the engine reaches about 120 degrees
Old 01-03-2007, 03:48 PM
3.4camaro's Avatar
slightly?
mine sounds like a chainsaw in between shifts
Old 01-03-2007, 09:56 PM
I was also told by my neighbor its a missfire.My plugs have about 6000 miles on them,they are NGK 555s . While i was changing my plugs i ripped my wires so i bought some new ones from autozone,they are real thing i needed them right away couldnt order MSD and wait for them to come in,(its a DD).I never had any problems with them until header install.Could it be there to thin for the headers?
Old 01-04-2007, 03:18 PM
SS1875's Avatar
May need to retune a bit , my car was still dumping fresh fuel on decel and making it Pop, also check for exhaust leaks.
Quick Reply: Popping sound after open headers
