Ok to clean MAF sensors with battery terminal cleaner?
Old 01-08-2007, 10:59 PM
Brian2006's Avatar
Default Ok to clean MAF sensors with battery terminal cleaner?
It's all I got and the local auto store didn't have electric or MAF cleaner. So, is it okay to clean the 3 sensors in the MAF with battery terminal cleaner?
Old 01-08-2007, 11:48 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I would use a carb cleaner spray.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
When you say battery terminal cleaner I am thinking that wire brush.
Old 01-09-2007, 12:47 AM
Grimes's Avatar
rubbing alcohol and q-tips are where it's at....
Old 01-09-2007, 09:29 AM
NastySSoo's Avatar
Ditto if MAF cleaner is not available! CRC makes some thats in my local auto parts store!
Paul
Old 01-09-2007, 09:42 AM
RobbieTransAm's Avatar
I used a non-chlorinated brake cleaner, and it worked great.
Old 01-09-2007, 09:54 AM
2000LS1TA's Avatar
+1 for the non-chlorinated brake cleaner
Old 01-09-2007, 10:03 AM
00454sscamaro's Avatar
i seen this stuff in a deisel shop the other day looks the same as the maf cleaner can.. dont know what the cleaning agents are in it though.
id get the maf cleaner spray or electronic cleaner , if you can.brake cleaner seems to be a bit harsher compared to electronic cleaner- when i use brake cleaner it gets almost anything off- where the electronics kinda weak in comparison.
Old 01-09-2007, 04:03 PM
FBDYLVR's Avatar
I use electronic contact cleaner..
Old 01-09-2007, 04:05 PM
Tainted's Avatar
carb cleaner will do jsut fine jsut dont touch the wires
Old 01-09-2007, 04:58 PM
Snyper's Avatar
I used alcohol with a cottom swab..and it worked great.
Old 01-09-2007, 08:44 PM
That's what she said...
TheBlurLS1's Avatar
I used some nail polish remover (that I borrowed from Jordan) and some Q-tips......
I couldn't believe how much **** was on those wires. They bend VERY easy, so do it gently.
Old 01-09-2007, 09:59 PM
1slow98Z28's Avatar
there is a MAF sensor cleaner out there i got it from auto zone i forget the brand name of it but just use the MAF cleaner not anything eles
Old 01-09-2007, 10:02 PM
BriancWS6's Avatar
Never saw the actual MAF cleaner, but alcohol and a q-tip has done the trick for me over the years.
Old 01-10-2007, 12:31 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Damnit! I forgot I gave that to you. I want it back. Along with the washable douche that you said you needed.
Old 01-10-2007, 12:40 AM
Ferocity02's Avatar
Old 01-10-2007, 12:51 AM
bww3588's Avatar
+1 no problems here. i used it when i got K&N oil on my MAF wires. i wasent consertive either. i used about half the can cleaning the TB out and the MAF. that oil just rolled out of that MAF.
Old 01-10-2007, 11:03 AM
koolaid_kid's Avatar
IMO, the most important thing is to check that the cleaner you select leaves no residue. I use brake cleaner, but I have also used electronic cleaner with the same results.
Quick Reply: Ok to clean MAF sensors with battery terminal cleaner?
