what are the BEST exhaust clamps?
For slip on headers to the Y-pipe (Pacesetters). I need something that WILL NOT leak. I hate exhaust leaks!!!!!!!!!!!! I use to used the 3" bus clamps that form around the pipe, yet those leaked.. bastards.
TIA.
TIA.
i have three stainless steel band clamps like the ones in the last link the guy above me posted. They are not supposed to leak at all. They are heavy duty from ThunderRacing.com and I think you tighten them to 60 ft. lbs. I have one 3" and two 2.5", let me know if you'd be interested at all
i've never had much luck with band clamps no matter how tight i get em...i think my next option will be the v-band clamps as I need to find something that doesnt leak so i can put in my wideband o2
i have v-band clamps on my FLP setup and they do leak when the pipes aren't matched up perfectly, which isn't the easiest thing to do sometimes. I would think band clamps would work better than v-clamps
3 bolt flange or V-band are your best bet.
**** band clamps, they will leak. I have about 7 band clamps in my garage that just sit there because they always leak on any of my setups.
I believe 4 of them in 3". I just want the best to which they will not leak, so if you wish, please either pm me a total, or you can just reply to this thread.
Thank you!
Thank you!
Originally Posted by TryingT/A
what is rtv, what does it stand for, and does pep boys carry it. Sorry for the hijack
Silicone rubber compound used as an all around sealer with differing formulations for different uses (such as high temp etc.)
Any parts or hardware stores should have it, I think I got a couple tubes of Hight temp at Pep Boys myself...
