Biggest MAF
Old 02-17-2007, 07:39 AM
aequitas's Avatar
Default Biggest MAF
What is the biggest MAF available? How big is the ls7 MAF?
Old 02-21-2007, 05:43 AM
WILWAXU's Avatar
The GM ZO6/Truck MAF is 85mm. Not sure about the newer LS7 stuff.
Old 02-21-2007, 07:37 AM
purdueranger's Avatar
LPE makes a 100mm MAF. that is one huge pipe.
Old 02-21-2007, 03:05 PM
3.4camaro's Avatar
i'd still port it
Old 02-21-2007, 03:13 PM
Tainted's Avatar
why bother with a MAF? go SD
Old 02-21-2007, 03:43 PM
jimmypop13's Avatar
i've been wondering, how does speed density work? It seems like having a maf would be the best way to go since it measures air & SD doesn't, but then again I know nothing about it. Is it good to use on a daily driver or would gas mileage go down. I guess I'll have to
Old 02-21-2007, 07:51 PM
joecar's Avatar
First you get the VE table dialed in based on wideband O2 data (you need to disable MAF and CL to do this);
When your VE table is dialed in, then the AFR commanded by the OLFA/PE tables shows up as actual AFR on the wideband O2 data;
Then, optionally, you re-enable the MAF and repeat the procedure to get the MAF table dialed in;
Then, optionally, you re-enable CL.
OLSD uses VE to calculate airmass, and uses the OLFA/PE tables for AFR.
CLSD uses VE to calculate airmass, and in CL uses NBO2 feedback for AFR, and in OL uses the the OLFA/PE tables for AFR.
OLMAF uses the MAF for airmass above 4K RPM, and VE/MAF below 4K RPM, and OLFA/PE tables for AFR.
CLMAF uses the MAF for airmass above 4K RPM, and VE/MAF below 4K RPM, and in CL uses NBO2 feedback for AFR, and in OL uses OLFA/PE tables for AFR.
Old 02-21-2007, 08:13 PM
Tainted's Avatar
OLMAF uses the MAF for airmass above 4K RPM, and VE/MAF below 4K RPM, and in OL uses OLFA/PE tables for AFR.
some1 translate that into english
Old 02-21-2007, 10:17 PM
jimmypop13's Avatar
oh, so instead of a maf, you need a wideband O2 sensor, perhaps one for each bank?? well I guess that kinda makes sense, though I didn't really understand a word of your "technical jargon" lol
Old 02-22-2007, 01:43 AM
chrs1313's Avatar
Originally Posted by 3.4camaro
i'd still port it
i almost **** myself when i read this...that is some funny ****
Old 02-22-2007, 09:24 AM
lsx24's Avatar
The flow of your MAF is going to be restricted by the TB, and the opening in the intake.
