98 valve covers compatible with 99 coil brackets?
I think you can bolt the '99 coils directly to the '98 valve cover. I bolted my '98 coils to my '99-'02 valve covers, but I had to use the '99-'02 bracket.
It sounds like you are trying to do the opposite, so it seems logical that you can bolt the '99 coils directly to the '98 valve cover, you just don't need the bracket..
*edit* - you may have a difference in thread size so there may be a problem with the bolt size. I remember that I had to re-tap the holes in the bracket to get the '98 coils to fit the bracket..
