Y pipe build size
Y pipe build size
Putting on a set of QTPs and gona hve my y pipe cutom built with high flow cats and flowmaster y collector. Should I have my y pipe built 2.5 inch or 3 inch
Originally Posted by NHRAMAN
Go 2.5..it is all u need + if u lower your car you will be happy you did...
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
NO LOWERING.....I agree then..... go 3" .mines 3" and speedbumps are troublesome to say the least.
2.5" inch collector is what will hold back the flow. With the Long Tubes you would be better off with a 3" or even a 3" x 3" ---> 3.5" collector. That would be best. Then 3.5" back to your catback. If going custom, they should be able to tuck it up there nicely, such that it won't hang low. With a ypipe your collector will be the biggest limiting factor in flow.
Thanks for all the info... I will be building it with those magna flow spun cats, (still trying to figure out which style) fowmaster collecters, and flowmaster merge. 3 inch it is!
Get the longer one or the shorter one?
Originally Posted by CAMJAG
On Flowmaster's web site they have the Y collector in 3 X 3.5 X 17.5 AND 3 X 3.5 X 18.5
Ok so how does this look for the y pipe build? Should have everything here besides the mandrel bends, and the clamps. Let me know if I am going 100% in the right direction
Flowmaster Y collector 3 x 4 x17.5
Flowmaster 3 inch to 3 inch ball flange kit (2 pairs)
Flowmaster reducer (Wrong size though) 3 inch to 4 inch
Magnaflow universal 59959 3 inch center spun mettalic cat
