Solid motor mount guys...
...what do you think of them? I searched and read stickies, but I didn't see much input from people who are using these. Found that most use poly.
Also, how was the install?
-My car is a non DD, cam/heads/high stall/LT's and true duals. I've got way too much flex and rubbing down below!
Originally Posted by orangeapeel
I love my solids. I have the Spohn's with a poly trans mount. Work like a charm! less rattles, but sometimes it will jar your teeth on some bumps!
If you do get spohn's. Good design, and great guys to deal with.
here's a link if you havnt cought it yet, https://ls1tech.com/forums/showthrea...0&page=1&pp=20
orangey what do you mean by jar your teeth on bumps? like potholes or speed bumps?
I have them. If you have clutch chatter, I highly suggest getting solids. They don't allow the engine to move back and forth. I now have zero chatter.
On the other hand, I have some extra interior vibration. At idle, the gauge bezel will vibrate along with the radio bezel. This all goes away once I get to driving.
Originally Posted by Hard Core Z28
I say go for the Spohn light weight motor mount stands with poly bushings. Still will hold the motor down with out rattling your brain when driving.
I take that back, at about 70 mph my gauge bezel had a slight vibration, but I used felt strips behind it (where it contacs the dash pad) and it got rid of it totally.
Another spohn solid mount owner here. I love them, install went easy, but I have deleted P/S, AC and abunch of other crap. If those were there, it might make it harder? No vibrations, running a MS3 with 4400 converter in a LQ9. Never noticed my engine moving either, until I saw some front angle pics of my car launching....wow tranny pan was bad tweaked.. These defenatly solved that problem. I say get 'um.
Chris
Chris
Don't know? Might be one of those "old man tricks" lol. Spohn don't say anything about that, and I like knowing my bolts are tight and a piece of rubber isn't what is controlling load on my engine mount bolts... Stick with what's proven.
Chris
Chris
Originally Posted by mr2guru
I don't see how one could need a more solid mount than poly??? Even with a donkey dick cam I couldn't see the motor move in my heavy iron 408 gto and poly mounts.
Do you guys with solid mounts not have any problems with your knock sensors?
