LSX? What can they do?
Restricted User
I have a question and would only like to hear some facts from you guys out in the world with LSX intakes. I don't want to hear stories that this is the best thing since sliced bread, I just want to know what kind of hp #'s can be made, what is better 78 or 90mm, and can it benefit my 224,224 LT car.
Let me know what you have seen or made along with the type of LSX.
Thanks,
Grant
Thanks,
Grant
Restricted User
I assume you mean a big cam. Well the car dyno right at 400rwhp. Not bad, but I think that the intake maybe a little over kill. Just trying to get facts on what people have experienced.
coming from a fast owner, unless you have plans for cubes, or are planning on taking advantage of the burst panels like in no2 and forced induction applications, your 224 will be fine with a simple ls6. I run no2, so I like the burst panels in case of a hiccup, and I plan to go bigger later so I spent the money once and did it right.
Restricted User
Originally Posted by SSmoked!
I agree!!! with your cam an LS6 intake is perfect! the only reason i went with the 90/90 is because im planing big heads/cam 383l and a blower! so i just went ahead and got it out of the way!! altough i did feel a nice diference for not having heads and cam!!!
when i was just cammed(tr224/112)in an stalled A4 with an ls6 intake i put down 348rwhp,and on a better day when it was not as humid i did 350rwhp.I added TSP 5.3 heads and A PORTED fast 90 and now at 417rwhp 407rwt. thats 67-69 rwhp with the heads and ported fast.If your gonna spend the money for afast intake just get it ported.Hope this helps you out
Originally Posted by BlackHawk131
So what kind of numbers did the both of you get going with the LSX and what kind of stuff do you have done to your cars?
See my thread here: https://ls1tech.com/forums/generation-iii-external-engine/699432-fast-85-85-track-results.html On a basically stock engine I gained roughly 20 HP.
You will see some gains over the LS6 even on a 224 but not as much as if it were a bigger cam. For comparison I dynoed 398/357 with LS6 and ported TB with a VERY lean tune. After fattening it up, adding an UD pulley and the FAST 90/90 it did 427/380 for a gain of 29RWHP and 23RWTQ.
