somthing every 98 ls1 owner should do....
Old 06-22-2007, 11:57 AM
5_02ls1's Avatar
Default somthing every 98 ls1 owner should do....
I guess im posting this in the correct place....if not mods can move it....
I had done a little research on the 98 knock sensors....
I found that they pull somthing like 4* of timing auromaticly....I thought it was bs myself but then one of mine went bad along with a cam sensor...
I replaced both knock sensors and the harness....the plug ins on the newer sensors are different so the newer harness has to be used....
This was one of the best performance mods ive done to the car....It sounds crazy but it unleashed a level of
that i had never seen in the car...
This topic really hasnt been discussed alot"I searched"
so i thought id share.....
Old 06-22-2007, 01:40 PM
Candyredz28's Avatar
How much was the harness, and how hard was it to install it.
Old 06-22-2007, 02:13 PM
1998LS1SS's Avatar
very interested, more info...
Old 06-22-2007, 02:16 PM
Black_Bird's Avatar
I'm pretty sure this was only on the '98 cars built before a certain date. I've had mine on my scanner numberous times and always had 0* of knock retard while sitting still and while driving around. Anyways, I think it was just the real early built ones or something, I'll try and find out. I freaked out the first time I heard this too, it's cause from them getting wet and messing up I believe.
Old 06-22-2007, 02:48 PM
PAGregSS's Avatar
Yes, they changed to the "new" knock sensors during production. My car was built late in the run and it has the new style knock sensors and harness. Never had a problem with knock or false knock.
Old 06-22-2007, 03:00 PM
01 BERGER CAMARO SS's Avatar
Damm, nice to know.
Old 06-22-2007, 04:06 PM
5_02ls1's Avatar
my car was an early 98 I guess one of the first ones......
I got the harness and sensors for free....they were off an 04 truck engine that my bro in law had replaced...the engine they sent him was a takeout anf had all the sensors on it....the sensors were low mileage sop i used them.....
the job is simple all you have to do is pull the intake and there directly under it....took me 2hrs but 1/2 an our of that was scraping gaskets"metal intake"....
your local dealership can tell you which sensors you have with your vin # and they can also be purchased there as well.....
Old 06-22-2007, 11:03 PM
Thule's Avatar
wow good to know this, my motor is out of the car , so i would like to do this, how much will i have to pay for new harness? and where to get it
Old 06-23-2007, 01:43 AM
Black_Bird's Avatar
Here's the info I dug up like a year ago, I guess it's still all the same, I havent checked.
Knock Sensors #10456603
Knock Sensor Harness #12575869
*non-sponsor link removed.
Old 06-23-2007, 05:30 AM
ez98ls1's Avatar
Get all the parts from sdpc2000.com. Here are the number you need.
12589867 sensors, this replaced 10456603
12601822 new harness.
I just ordered both and the total was around $130.
Old 06-23-2007, 12:31 PM
Mystic 98 TA's Avatar
So... what exactly is this gonna do to the car?? I dont know much/anything about Knock Sensors I bet i have the old knock sensors... Build date for my car is November of 97. Just make the car run smoother?? I'll be replacing the intake manifold soon, so i might be interested in this, for the $130 you guys are talking about.
-Charlie
Old 06-23-2007, 06:25 PM
ez98ls1's Avatar
If your 98 suffers from knock retard then upgrading to the newer style will in most cases ease some of the knock retard. A false knock will retard the timing making you lose horsepower. since I am upgrading intakes I figured I might as well change out the knock sensors for peice of mind and because the old ones have 88000 miles on them.
Old 06-23-2007, 06:31 PM
'Trust''s Avatar
I can attest to this aswell, my car always pulled timing and recieved KR, we desenstized them and didn't get too much help. I had a new motor put in because of an issue with my old one, the new one came with 02 sensor and I haven't had a problem since.
Edit: My car was built 09/22/97
Old 06-23-2007, 10:42 PM
WILWAXU's Avatar
Please do not post non-sponsor links.
Old 06-24-2007, 09:22 AM
bad6as's Avatar
i herd the same about the false knock they put off. i have a couple friends that work ata gm shop and we where gonna drive with a tech II to see if there was knock
my cars build date was 4/23/98
Old 06-24-2007, 09:32 AM
Wolfgang427's Avatar
Wow, you learn something new every day. Never had that problem on my 98, but then again mine is a late 5-98 production#.
Old 06-24-2007, 11:20 AM
LS1W66's Avatar
It would be nice to know the date that they started using the new sensors.
Mine was built 3/11/98 and always seemed to be an exceptionally strong runner.
Old 06-24-2007, 02:33 PM
ez98ls1's Avatar
How did you find out that your car was 1 of 22? I have a 98 HT M6 Formula as well. the build date was 3/98 for me.
Old 06-24-2007, 05:57 PM
bww3588's Avatar
is there any way to tell by looking at them, which sensors/harness you have?
Old 06-24-2007, 06:03 PM
5_02ls1's Avatar
Default yep
on the plug in part of the old sensore it is long and slender the new oines are short and stubby....
Quick Reply: somthing every 98 ls1 owner should do....
