Lead proof 02 sensors working
6600 rpm clutch dump of death Administrator
Many folks have been running 110 and 116 octane on these in the fast GN's and they just keep going with no fouling. On a GM o2 they'd get one run before it was toast.
http://www.turbobuick.com/forums/sho...threadid=65765
!Dial-up Director
Re: Lead proof 02 sensors working
Denso P/N 234-4018 - 4 wire heater o2 sensor - $55
Denso P/N 234-1001 - non heated - $26
Monarch Products
909-627-8501
Will that 4 wire sensor work for us?
Justin
Monarch Products
909-627-8501
Justin
I would also like to know if these will work. I went through my last set of 02s in about 300 miles and that was with running UNLEADED 100 octane. I may as well have been running leaded gas if they're going to die on me anyway.
Do we need a heated sensor? I know the factory ones are heated but dont you just have to give them a few minutes and they heat up by themselves? With Prochargers you're not supposed to go over 2Krpms until at operating temp anyway so wouldnt really matter to me. I hope somebody can tell us if we can use these sensors.
Justin
Justin
From
http://www.densoaftermarket.com/onli...p;model=CAMARO
SS V8/5.7 25312197 -- Rear 234-4025 234-4000
SS V8/5.7 25312197 Left Front 234-4025 234-4000
Z28 V8/5.7 25312196 Right Front 234-4087 234-4000
Z28 V8/5.7 25312197 -- Rear 234-4025 234-4000
Z28 V8/5.7 25312197 Left Front 234-4025 234-4000
Aren't the two front O2's the same part number? I bought new ones from NAPA and they had separate part numbers but the left side front had the wrong plug so they got me another one with the right side part number and thats what I'm running. Is this not a good thing?
234-4025 Front Left
234-4087 Front Right
For all 98-2002 Fbods
www.sparkplugs.com
~170$ Shipped for both
www.sparkplugs.com
LS1Tech Co-Founder
Very interesting!!!
Do we need to run heated o2 sensors? I think LT1's, maybe just obdII cars raan unheated sensors, I'd like to know asap I am willing to try these.
From reading that thread it sounds like running some pump gas will clean them up if they start to slow down...
Any updates?
I went 1/2 tank of race gas like 1.5 yrs ago and it killed the 02's.
Any updates?
sorry to dig this thread from the grave but I ran a search on running DENSO 02 sensors and this thread came up.
You do have to run a heated 02 sensor; unless you would like to change the harness connector on the 02 sensor. You will most likely get a DTC for 02 sensor heater circuit, that could always be tuned out.
On some early model (89-91etc) GM trucks i've heard of independant repair shops offering to install a heated 02 sensor+heater realay and circuit, many of thoes trucks get a surging misfire at idle. The belif is the heater circuit maintains 02 sensor voltage at idle where there is less exhaust pulses the sensor may not be able to maintain a consistant voltage. The 02 sensors chemical reaction that creates voltage needs heat in order to conduct itself, thats why you see companys now or california emissions cars switching to air fuel sensors they don't need a warmup time.
I bought the factory replacement denso o2's for 98-02 fbody from www.sparkplugs.com
Ive ran alot of leaded race gas with no problems so far...they plug right in
The densos have an aluminumoxide sheild on them that catches contaminants before
it reaches the active element of the sensor . This is how they work their magic.In testing they are at least twice as tolerant of silicone and lead poisoning.Hope you
like them ,I do.
like them ,I do.
