Trying to find a catted y
I tried ordering a catted y pipe from Texas Speed and Performance and received an email stating that it was on back order for 4 to 6 weeks! Anybody else on here sell them?
Moderator
You might be money ahead (not to mention time waiting)
by getting a good quality stainless offroad Y, not that
there are that many) and a pair of minimum-size bullet
cats and have the Y cut and the cats inserted and weld
it up to suit you. Or maybe even square-flange the cats
and pipe stubs for easier R&R later. I don't think that
ought to be more than another $100 at the outside at
an exhaust shop on a slow day. The price premium on
catted Ys seems to at least cover the material cost of
good cats (especially if you shop around). You can
run the offroad pipe until you find the cats Bear in
mind that forced induction really adds to the heat you
throw down the exhaust pipe and some cats, esp. the
metallic wire-ball ones like Jet-Hot, are easily destroyed
if you defeat the catalyst overtemp protection and wail
on it for any kind of duration. The Jet Hot Y is, I believe,
a straight match to Hooker pipes but I've seen some who
say they've blown out the little insert cats more than
once, blower dudes. And I was unimpressed with the
quality of the merge, I spent a couple of hours with a
flex-shaft grinder up in it removing bad stick-in pipe
edges.
Depending on your inspection regime and your philosophy
as regards legalities, getting generic empty cat shells
tacked onto the pipe might work for you.
Depends if it's a stop-and-frisk, or a full cavity search.
Waiting for sponsors to notice your thread is an iffy
proposition. Some are hungry, some just pay for ads and
go about their regular business.
edges.
