Fuel line to close to cat??! advice needed
Old 08-30-2007, 09:11 AM
ApexVIII's Avatar
Default Fuel line to close to cat??! advice needed
ok so i did a little custom work, i put on some cats on with my LT. one of the cats at about 1.5" from my fuel lines. is that to close? i put exhaust heat wrap around the fuelk line and some around the cat.
is this ok or safe?
```Before```
```And after some heat tape```
Old 08-30-2007, 02:08 PM
ApexVIII's Avatar
to the top
Old 08-30-2007, 02:57 PM
nitroushane's Avatar
Can you put up a pic?
Old 08-30-2007, 06:33 PM
ApexVIII's Avatar
yea i will in a little while
Thanks!
Old 08-30-2007, 08:52 PM
nytmare1's Avatar
I had some cats welded onto my XS y-pipe and the driver side cat sits just under the fuel lines too. I had some heat wrap laying around that's used for protecting the O2 wires after a LT install. I wrapped the fuel lines with it and zipped tied it in place. It's been about 1,500 to 2,000 miles so far in thick traffic (Washington, DC area) on some pretty hot days. So far, so good...
Marc
Old 08-31-2007, 12:57 AM
ApexVIII's Avatar
ok i went and bought some thermo tec heat reflective wrap and put it around it i think its good now.
Old 08-31-2007, 03:52 PM
ApexVIII's Avatar
bump added pic's
Old 09-01-2007, 12:06 AM
Da Swami's Avatar
No problem.
Fuel hard line is rated to very extreme temperatures.
The only time you would have to worry is in a carbureted car, being under low fuel pressure, you can have vapor lock due to bubbles developing in the fuel.
Old 09-04-2007, 12:16 PM
ApexVIII's Avatar
so this is safe nothing to worrie about?
thanks alot!!
Old 09-13-2007, 10:23 AM
ApexVIII's Avatar
i think the heat shiled did the trick they are not hot any more lol
