Bosch 13111 sensors.. tuner said i cant use these... why???
so i took my car to speed inc.
there brand newBosch 13111 o2 sensors in there and they said you cant tune with these that there to slow at reading?? is this correct.
anyone else had there car tuned on the Bosch 13111 sensor
Tech Resident
You can use them, but they're complained about often. I decided to just get O2 extensions after hearing numerous complaints about the Bosch 13111's and how slow they are when compared to stock or Denso O2 sensors. They have a very bad reputation with tuners. When my stockers go, I'll pick up a set of Denso's. Everything Bosch makes is junk.
When I bought my longtubes and researched what O2 sensors everyone used and what everyone recommended, the definitive answer was......(drum roll please)......yup, BOSCH 13111's...
now they're junk...
Tech Resident
Now that the feedback started coming in, tuners started to see how much of a problem these O2's are. They don't last nearly as long as the stock O2's, the heaters seem to be weaker, they typically switch slower (that's not to say people haven't had good luck with them, but they have a much higher problem rate than AC Delco or Denso O2's)...so now they're discouraged by tuners. It takes a while for experienced people to pass judgment on the product. Tuners don't like them. That should say something about them.
When my O2's go, I will be putting in a set of Denso's. Denso plugs came in our cars stock, correct? Because I bought my car with 24,xxx miles on it, so I assume the plugs were stock when I changed them - they were Denso's. I pulled them out at 45,000 miles and switched to NGK TR-55's. I may as well have kept the stock Denso's because they looked brand new! Denso makes some great quality stuff, unlike Bosch, which is typically junk.
My Bosch wiper blades are nice though Over a year and still look brand new, driven in rain and snow.
