please help me ????????
Old 12-13-2007, 09:00 PM
sl99ls1's Avatar
Angry please help me ????????
ok i was driving home on the freeway and my ses light started flashing, its been on because i dont have cats. but my car start shacking when i got on the gas, when i got off the freeway there was a little white smoke coming out my tail pipes and the light would stop flashing at an idel. i changed my spark plugs and my o2 sensors and its still doing this and it has never over heated and it has normal temp and the oil is fine please help???
__________________
Old 12-13-2007, 09:04 PM
litle88's Avatar
Flashing light (ses) is a misfire brotha!
If you can get to an autozone they will read your codes for free, get them and get back to us.
Old 12-13-2007, 09:21 PM
sl99ls1's Avatar
i did and it was just the one for not havin my rear o2 sensors in
Old 12-13-2007, 09:26 PM
litle88's Avatar
got the numbers?
Old 12-13-2007, 09:30 PM
sl99ls1's Avatar
na i forgot them
Old 12-13-2007, 09:32 PM
litle88's Avatar
how do you know what they are for?
Old 12-13-2007, 09:34 PM
sl99ls1's Avatar
my friend works at firestone and scanned them and it tells you what it is, its a snap on scanner
Old 12-13-2007, 09:48 PM
litle88's Avatar
WOW I never heard of this, but maybe it is your fuel injectors ( like one going out while under load?)
Add some fuel injector cleaner, a coilpack?
How many miles?
Old 12-13-2007, 10:15 PM
Tech Resident
ChocoTaco369's Avatar
POP goes the spark plug!
Sounds like you have a bad plug.
Old 03-05-2008, 12:13 AM
sl99ls1's Avatar
this is the code i got p1133
Old 03-05-2008, 12:17 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
that is an o2 sensor heat code. Misfire will cause the light to flash like said before. Never have I seen one flash from the oxygen sensors, and I have run dyno time on a lot of cars. That is from a front o2 sensor, so you may have a fouled out one that is just not getting the heat it needs. As for the flashing code. You probably won't get one unless you data log it with EFI Live or something. Also can't help but notice that you have changed out your wires from stock to MSD's. I would check your plugs and possibly get some stock LS2 wires and send those MSD's packing if it still doesnt clear up from the plug check/change. My guess if it is a coil pack causing it it will show up as #7.
