Exhuast dumped question
Old 02-17-2008, 08:33 PM
jessedale98's Avatar
Default Exhuast dumped question
I have LT's and a y-pipe on my car only right now. Its loud and got me pulled over. I purchased a Moroso Spiral flow, but only one. I want it dumped but not sure how to hook it up. and i need to to be quieted down considerably.
Should the spriral flow be hooked directly up to my y-pipe? Im confused here. Please help
Old 02-17-2008, 08:44 PM
Full-Force's Avatar
A spiral flo on the end of a y pipe is one off the best sounding systems out there, I have built and installed a few. It will quieten it down alot. The end of your y pipe is a smaller diameter than the y pipe itseld so a 3" pipe can slip over it. The spiral flow is made to slip OVER a 3" pipe so you really need to either cut that small end of the y pipe off or have it expanded to 3" so the spiral flo is a tight slip fit. Put you a good band clamp on it and call it a day. No hanger even needed if you are using the y pipe factory hanger because that muffler is so light it will still be very rigid on the end.
Old 02-17-2008, 10:01 PM
oh, so no welding will be needed?
Old 02-17-2008, 10:46 PM
tripps's Avatar
Damn i've heard that before, and it is extremely loud!! Ever thought about catback with a cutout in the I-pipe?
Old 02-17-2008, 10:55 PM
Well, i wanted to use the LEAST amount of material I can to save weight. So dumps are the best bet. Are you saying the spiral flow will be louder than just LT's and a Y pipe? Cause thats pretty ******* loud.
Old 02-18-2008, 11:05 AM
tripps's Avatar
No a spiral flow on the end of the y-pipe should quiet it down some, but its still gonna be pretty loud.
Old 02-18-2008, 04:11 PM
Well lets put it this way, in its current state its a cop caller. I want it to be less of a signal to the cops of where I am, I hope this will do just that.
Old 02-18-2008, 08:22 PM
Full-Force's Avatar
Take your y pipe off. Take it to the muffler shop and have the end expanded to 3". Go back home and install the y pipe. Slide the spiral flo on to the y pipe and clamp it with a band clamp. Your done. Like I said, if you are using the stock y pipe mount that mounts off the side of the tranny you will not even need a hanger. It will be very stiff and rigid. No bouncing. Its just too light.
It is honestly out of all the exhaust I have had on my car, and thats alot, the best sounding I ever had.
Old 02-18-2008, 08:38 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I use 2 spiral flows on mine to tame it down, one on each side though off the over axle x-pipe setup. Sounds great. Out of the 5 different setups I have had for exhaust I like it the most as well.
Old 02-18-2008, 08:54 PM
WS6 SRT-8's Avatar
Here is mine with about a foot of 3" pipe off of the "Y" and a Spiral Flow dumped before the axle. I think it's pretty damn loud. I might end up going with a catback. It does sound good though!http://s128.photobucket.com/albums/p...t=MOV00001.flv
Old 02-18-2008, 09:11 PM
Thanks guys, I apprectiate the input.
Old 02-18-2008, 09:18 PM
man, i wish you had a cruising video with a WOT pull, that would help me out tons. but it sounds really good with yoursetup
Old 02-19-2008, 11:19 AM
WS6 SRT-8's Avatar
Thanks for the compliment. If we get some decent weather, I'll try to get a drive by for you.
Old 09-17-2008, 04:25 PM
White.Lightning's Avatar
TTT. How about that video of the WOT and drive by?
Old 09-17-2008, 04:35 PM
krazy4's Avatar
You could sell the spiral flow and get a Magnaflow 4x9 muffler. Should be quieter, but still sound good.
That is what I am going to be doing within the next couple of days.
Old 09-17-2008, 04:49 PM
bongva's Avatar
wow sounds awesome!!!
doesnt seem too loud either!
