Cam only with 90/90
Cam only with 90/90
How many of ya are running the 90/90 or new 92/92 cam only? I'm thinking of buying one for my 346 all bolt on MTI X1 cam only setup. List setups, and how much power you're making! Thanks-
I wanted heads, but the intake would be a lot easier to install!
i'm in the EXACT same boat as you.
i want to "do something" to my car...i've been itching to...but i don't have the funds to do head correctly (new injectors, bolts, retune, misc), not to mention i'd like to do better than budget heads.
i've been throwing around the FAST...since you can pick em up for $1200 or less (used much less).
and the swap is straight forward and doable in a short time (working in my apartment parking lot).
i don't think you'll see the gains some guys get, but it should be considerable.
would love to see a before/after dyno run.
I put down 384/346 with a 224/228 cam.
Dyno and mod list in sig.
Also, I prob should be pulling more than that cause I'm tuning it myself and I can't say I'm exactly a professional grade tuner. I like to think I could get 390/350 or so, but thats speculation.
I have seen ported 90/90 combos do much better than this on agressive set-ups you just have to spin higher to really take FULL advantage of a 90/90. If your not spinning 6500+ I don't think the FAST is worth the extra $$ over an LS6.
They just had a back to back dyno on a bolton ls6 vette and the ported 92 swap yeilded 28rwhp and 27rwtq more. It might not be entirley worth it to swap from ls6 to fast, but its definatly worth it to me to swap from an LS1 intake to a ported 92/92 combo.
better gains, but you're still tallking more money, and a significant increase in labor needed to do the swap.
whether it be "paid labor" which will add to the cost, or "required knowledge to DIY"...a head swap is considerably more than an intake swap.
the other side of it is if you're already running the cam...and it's tuned....you'll hve to pay $500 for another tune after heads. not to mention the cost of the install parts.
most heads will require new injectors...$250-300
head bolts - $50
head gaskets - $50-100
dyno tune - $300-500
so you're looking at almost $1000 worth of misc expendatures on top of the heads. so even if you do budget heads (which tend to yield budget hp) you're still pushing the $2000 mark, and getting maybe 30-40hp.
where a FAST intake costs $1100 (TR has a package i think) and you'll gain 15-20hp.
and if you have an LS6 intake already...you'll recoup $300-400 by selling that and the TB.
and the FAST is something a guy can install in his driveway in an afternoon.
head bolts - $50
https://ls1tech.com/forums/dynamometer-results-comparisons/895368-fast-92mm-results-i-wouldnt-believe-myself-if-i-didnt-see-first-hand.html
And btw they dont make 90/90's anymore its all 92/92 now.
i have the tsp heads cam package & dynoed 406 on a mustang dyno & i just ordered my fast 92/92 i would be happy with 32 more hp,hell i might get more since you dont have heads!
