high mile head and cam install
Old 08-07-2008, 10:42 PM
ItalianZ28Stallion's Avatar
Default high mile head and cam install
i have a 99 z28 with 140xxx and i am going to put heads and cam long tubes intake tb and all of the other things that you need to for all the bolt ons is this a good idea
Old 08-07-2008, 10:54 PM
jetlag's Avatar
Um...YES!
Old 08-07-2008, 11:22 PM
LebaneseShowoff's Avatar
**** yeah its a good idea, i did a Cam on my car with 138K miles, it now has 140K and still runs good, dont forget the Ported LS6 oil pump. Good luck and keep us updated, im looking for some heads right now.
Old 08-07-2008, 11:24 PM
waterbug1999's Avatar
Yea.. I did mine with 100,000 miles on it... Just dont cut corners and reuse the timing chain, lifters, oil pump, etc.... Something as cheap as that can break and its all over.
Old 08-08-2008, 07:04 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Depends on your planned uses and goals. If gas mileage is a concern I would say it is a bad idea. Obviously you aren't wanting to do that though because performance and good mileage are like mixing oil and water. Tough to have both. Sure it is a good idea. Do your research as far as heads and cam combos though. That is the main thing.
Old 08-08-2008, 07:33 AM
Raise's Avatar
The question to ask yourself is, if and when the bottom end goes, will you be replacing with stock cubes or a bigger bottom end? That should help you pick a good head/cam combo that you can transfer over to the new block...or help you decide whether you want to do it now or wait for a new bottom end.
Old 08-08-2008, 10:17 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well I wouldn't run the same heads/cam on a 346 that I would run on a 408 with the same goals and aspirations. But that might just be me.
Old 08-08-2008, 10:34 AM
Raise's Avatar
Well thats exactly my point. He might want to wait until he knows what hes gonna do about a bottom end. I wouldnt run the same combo either on a 346 vs a 408. But he could go with a good size set of heads and cam that might work well on a forged 347 as well as his stock 346. It all depends on what he plans to do in the future.
Old 08-08-2008, 02:12 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That was what I thought you were saying, but was just trying to verify for the OP.
Old 08-08-2008, 03:30 PM
Raise's Avatar
Gotcha
Hey man, you still have the same ride? The hugger SS?
Old 08-09-2008, 12:31 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Gotcha
Lol, probably not for long.
