Help, got a stupid problem!!
Old 08-22-2008, 06:45 PM
Z'mnypit's Avatar
Default Help, got a stupid problem!!
Ok, I sold my FAST intake and 90mm NW TB and bought an LS6 intake and TB. I swapped them out yesterday and put the TB on today. Now my throttle cable is about 1/2in too short. Everything was fine with the FAST setup. Ive checked all three cables and all look fine. Ive pulled the clips off the two cables to make sure my problem wasnt where they can be adjusted. Ive checked the bracket on the side of the intake that holds the cable, Its as far foward as it can go. Im baffled as to whats happening. You cant even pull enough slack out of the cable to get it to work. I hooked it up anyways so I could pull the car out of the garage to keep the fumes out of the house and the idle is at 3000rpm with the cable like it is. Anyone got any suggestions on what to look for? Like I said all was fine before earlier this week when I had the FAST setup still on there.
Thanks
Old 08-22-2008, 06:58 PM
ZDOG's Avatar
make sure nothing got caught up at the pedal when the cable was released from the fast? dont know.......
Old 08-22-2008, 07:19 PM
Z'mnypit's Avatar
just checked it and its fine. I pulled it pretty hard and you can pull the slack out of it with some effort but it goes right back as soon as you let go of it
Old 08-22-2008, 07:21 PM
XtraCajunSS's Avatar
What year is your car? There are 2 style throttle bodies for the 4th gen LS1 (98-99 and 2000 and up) cars. One has a small cam on the linkage and the other has a large cam. They each require that year specific throttle cable to function correctly.
Thanks,
Shane
Old 08-22-2008, 07:34 PM
Z'mnypit's Avatar
Thanks,
Shane
Its a 99. Im not sure what the intake and TB came from. You talking about a cam in the TCS thing by the battery?
Old 08-24-2008, 08:35 AM
Z'mnypit's Avatar
Guess Ill just have to modify the bracket so it will shift forward another half in or so.
Old 08-24-2008, 01:08 PM
Soul TKR's Avatar
why would you sale a fast and downgrade to the LS6?
Old 08-24-2008, 02:48 PM
c0ncEpT's Avatar
Same reason he sold his 408?
Old 08-24-2008, 07:24 PM
Z'mnypit's Avatar
Because I dont care about goin fast anymore. I just want to enjoy the car now. Plus I planned on using the extra money.
