Ported throttle body - high idle
Just put on a new jantzer ported tb.
Idle seems slightly high. The throttle position sensor is reading .6 volts at zero throttle. Is that normal or should it be 0? (this is according to my scangauge plugged into obdii port)
I heard there is a screw I can adjust to fix that? Where is it?
Attachment 150029
Here you go! Click on the attachment to open.....its a PDF, the only way I could think of uploading an image on here.
