main bolts reuse,torque?
What if you want to check bearing clearances? Bolts are torqued up? Do you Get new ones every time? I am assembling a close to stock engine. On my race engine i used all ARP hardware (studs) so this was not a issue. The engine that is mostly stock will be used for back up,i really do not want to spend the money on studs. Is there a alternative bolt that can be purchased. Thanks JC
I definately got different different torque numbers than that link when I looked them up when I worked at the dealership. It said to torque the inner to 15 ft lbs and then 80 degrees and the outer to 15ft lbs and the 51 degrees. The rod bolts were different too. 15ft lbs and then 85 degrees.
Tighten the M11 cylinder head bolts (1-10) a first pass in sequence to 30 N·m (22 lb ft).
Tighten the M11 cylinder head bolts (1-10) a second pass in sequence to 90 degrees using the J 36660-A .
Tighten the M11 cylinder head bolts (1,2,3,4,5,6,7,8) to 90 degrees and the M11 cylinder head bolts (9 and 10) to 50 degrees a final pass in sequence to using the J 36660-A .
Tighten the M8 cylinder head bolts (11,12,13,14,15) to 30 N·m (22 lb ft). Begin with the center bolt (11) and alternating side-to-side, work outward tightening all of the bolts.
http://www.ls1howto.com/index.php?category=1
I blew the holes out with air a used 30w oil on the threads.
