Cold Oil=Happy, Warm Oil=tick, tick, tick
Old 10-13-2008, 06:02 PM
11secLS1's Avatar
Default Cold Oil=Happy, Warm Oil=tick, tick, tick
Yeah, I know that this subject has been beat to death, but I will add my story. I am 99% sure I know what is wrong, but I want to get some opinions anyways.
When I first start the engine, everything sounds great. Normal sewing machine noise, but otherwise quiet. As the engine temp comes up, I hear a defenitive tick, and It gets louder and louder as the eninge warms up. It is very noticible from both inside and outside the vehicle. The sound appears to originate from lower in the engine, near the......lifter area.
Any similar experiences?
Old 10-13-2008, 06:14 PM
conan's Avatar
Sounds like lifters to me. What weight oil are you running.
Old 10-13-2008, 06:18 PM
th41427's Avatar
Default ?
I have the same problem. what weight oil should i be running? thanks
Old 10-13-2008, 07:22 PM
11secLS1's Avatar
I am running 10W40. I have tried 20W50 VR1, 10w30 synthetic. **** they all sound the same.
Old 10-13-2008, 08:23 PM
conan's Avatar
If going to thicker or thiner oils dont change things, might want to pull the heads and see whats going on.
Old 10-13-2008, 08:42 PM
SOMbitch's Avatar
Yep ...... my bet is lifters too... could be worse...
Old 10-13-2008, 09:38 PM
98cherrySS's Avatar
I'm in the same boat... Oil pressure is good. Car runs great. Just ticks. Does your tick come and go?
Old 10-14-2008, 07:01 AM
Nabdrill's Avatar
I had the same thing on a stock high mileage LS1. Cold=good, warm=bad. When I got it apart I had a lobe wiping on the cam. I figured that the lifter was losing prime here and there and finally starting to damage the cam.
It wouldn't be that hard to pull the cam and take a look at the lobes
Old 11-07-2008, 01:14 PM
sergo's Avatar
i've got the exact same issue with my goat right now. cold=quiet warm=ticking.
