LS1 heads on a truck 5.3
A friend has an ,04 Avalanche with a 5.3 that's losing a gallon of coolant every 2k. Chevy wants $3300 to replace the heads.
I have a set of LS1 haeds off my '98 TA with PRC Gold springs and new seals.
Wiil they fit and what effect wpuld they have on compression?
they will fit just fine but you will drop .4 of compression which is nothing really. but you will benifit a little with the bigger valve size on the ls1 head compared to the 5.3. should make for an easy swap
Those heads should fit just fine. You will lose a little compression though. As far as the valve covers go, just swap out to the center bolt style. It will be much cheaper that paying $3300
Yes and yes but I know for a fact that you cant put them on his truck unless you get perimeter valve covers with the perimeter coil pack brackets you cant put his valvecovers on your old heads it just wont work. lookup 98 heads vs 99-02. find pictures and then you will understand a lil better let me know
LS1Tech Premium Sponsor
That drop in compression is NOT what you want for a DD truck! The 5.3L trucks come off the show-room floor with about 9.5:1 static compression, and that LS1 head is going to bring that even lower like stated. Compression = torque! You need that bottom end and mid-range torque to move that heavy truck!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
