Is the block surface clean enough?
if you dont have a air grinder go get yourself a gasket scraper and use brake clean also. brake clean evaporates quickly and will eat the **** out of that old gasket material.
UNDER PRESSURE MOD
It's tough to remove the composite gasket material with a scraper sometimes, but like mentioned earlier, it comes off pretty easily with brake clener and a scotchbrite pad. I found a bag of the blue scotchbrites which are supposedly 'scratch free' that I use to clean some areas of the underhood and undercarriage with good success.
