which heads would be best to use with the Torquer V3
02 T/A Torquer V3, Pacesetter LT, SLP lid, want to add heads but dont know which would be the best to pick up good power...please help
Definitely the budget head would be the PRC 5.3 Stage 2.5s. If you've got the coin, some AFRs would really rock your socks, but I think if I had a sweet set of AFRs I would definitely go with a different cam than the Torquer V3. It's just a matter of matching the right heads with the right cam.
LS1Tech Premium Sponsor
The PRC Stage 2.5 5.3l head is a great budget option. From a engine dyno standpoint they compare very well next to the heads being discussed. If your willing to spend a little more than $1200 then the PRC 215 cylinder heads should be ready in about a month! The question you have to ask yourself is what's your ultimate goals for the car. You can buy $1200 cylinder heads that make 40rwhp gain & $1100 intake & tb combo that makes 35rwhp gains for cheaper than you can buy most aftermarket casting cylinder heads that best case might make 45rwhp....
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
I noticed your in Borger, shoot me a pm I have a few test combos we might be able to work out testing on your car...
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
PRC 215 heads for just over 1200 huh? that more than cuaght my interest. cant wait to see them in action. any predictions on flow numbers? (that you wanna release)
I have a cam similar to a TQv2 with a set of TEA ported 5.3L heads and Im over 450. I would imagine if I had a newer higher end head I would get a good bump in power.
The heads from Texas Speed are great heads, especially for the price. You really cant go wrong.
