Reluctor Wheel Removal
What are you guys doing when you remove the reluctor wheel? How does the engine react to this? Can you continue to use the stock PCM? Im lost in every way except why you would remove it. So any help would be appreciated. Again main concerns, Once removed what reads timing? Is that all it reads? Can you uses stock PCM if removed? Thanks.
Russ
With the reluctor wheel it comes in contact with aftermarket pistons. I was explained by diamond that if I removed it they could make an even skirt around the entire piston instead of a flat spot on each side where the pin goes through. I guess I am incorrect? Dont know this is what Diamond told me. Maybe they are wrong.
Moderator
The reluctor is how the ECM reads crank position, which is vital to engine operation. Aftermarket systems use a reluctor on the balancer, but I don't know if that will work with a stock computer. The other option is to run a distributor.
I don't know about Diamond, but Wiseco, JE, Mahle, and CP pistons don't seem to have any problems designing a piston to clear the reluctor.
The original post is here:
https://ls1tech.com/forums/generatio...fo-inside.html
--JMarsa
What you are saying makes no sense, unless the skirt comes so low it hits the wheel. Look where the reluctor wheel is in this photo:
--JMarsa
--JMarsa
Moderator
I must assume this is what they wanted me to do. They didnt have an issue making a Piston to clear the reluctor they just mentioned they could make a "better" piston if it was removed. You know how they mill a section of the piston away on the skirt to make clearance for the reluctor wheel? I guess they think it would be better if that section was still there and the entire piston was round at the skirt instead of milled away. Like I said Im not sure, this is just what they said to me.
isn't as good as this type of skirt:
Maybe it is, maybe it isn't. But I have seen 900hp naturally aspirated 427 C5R's use the skirt like in picture #1 (and no reluctor wheel). I have also seen 2000hp turbo LSX engines (again, no reluctor wheels) with skirts like in picture #1. But I have seen heavy ""strutted" skirt pistons, like in picture #2, in lower power BBC Chevy and Viper engines. I really haven't looked into this, but all I can tell you is the trend I have seen. The better engines seem to use the "slipper" skirts.
I got what you're saying. Diamond thinks this type of skirt:
I was with him when the diamond tech told him this. I think he said he relocated it but I'm not 100% sure on this. And he knew what he was talking about so if you have no knowledge on the subject I wouldn't be so quick to call BS or call someone who does this for a living a dumbass.
Russ
Moderator
I wasn't aware that you were there and heard the conversation. And I fail to see where I claimed to know something that I don't or called BS on something I have no experience with. All that I was stating was that 1999transamws6 heard correctly about moving the reluctor wheel.
And for the record that post wasn't directed towards you since you provided some factual information instead of a useless post to increase your post count.
Moderator
You don't come in here acting the way you did.
No one called anyone a dumbass or anything insulting for that matter. It seems neither of you really even know what the "tech guy" was saying, so I would just take what people say in here and be happy. If you think we are so unknowledgeable, you can call that diamond tech guy back for clarification.
