which plugs?
Old 12-22-2008, 05:15 PM
gobigorgohome's Avatar
Default which plugs?
hopefully this is the right place for this, im a newb i have a ls1 out of 99 camaro in my rock crawling buggy. Full tube chassis. motor has polished crank, 11.25 to 1 compression. small chamber heads, 550 lift cam. Howell harness and computer. Sanderson custom headers. run it on race gas. What kind of plugs should i buy i was thinking heat range of 8 but with race gas i just dont know.
what about these
http://store.summitracing.com/partde...?part=NGK-7173
Old 12-22-2008, 05:45 PM
vandal0-0's Avatar
Rule of thumb is tr55 N/A,tr6 nitrous and low boost,and 7 and so on for higher boost levels and big shots of nitrous
Old 12-22-2008, 09:25 PM
Sigforty's Avatar
You will be fine with some TR55 or TR6 plugs from NGK.
Old 12-22-2008, 11:10 PM
do they sell those at the local parts store?
Old 12-22-2008, 11:54 PM
Justin93's Avatar
with that kind of compression Id say go with a TR6 its a bit colder, and get a good tune and make sure its not too lean other wise say bye bye to #7. The ws6store.com sells the tr6's as does any parts house.
Old 12-23-2008, 09:25 AM
slt200mph's Avatar
With that much compression you should use the TR6 plug......I get them at advance auto parts for $1.99 a piece.
Old 12-23-2008, 09:29 AM
Sigforty's Avatar
Try O'Rielly Auto or Advance Auto parts stores. Ask for NGK stock No. 3951 for the Tr55s or 4177 for the Tr6. I know my local O'Rielly sells the Tr6 plus for under 1.60 a plug. Advanced is slightly more expensive.
Old 12-23-2008, 10:09 AM
thanks for the info
Old 12-23-2008, 12:31 PM
99blancoSS's Avatar
FI and hi compression guys use the TR6, although for the hi compression guys a tuner will tell you to use them if you have detonation and stick the TR55 if not.
I sell the TR55 and TR6 for $18 delivered or with a set of MSD 8.5mm Superconductors for $68 delivered.
Old 12-23-2008, 03:12 PM
JBIRD02's Avatar
I agree with these guys. Run the TR6's. I'm about to install my heads in a week or so, and I picked up a set of the TR6's because I should be @ atleast 11:1
Old 12-23-2008, 06:45 PM
Banned Village Idiot
LS1BLKSS's Avatar
get the tr55's
Old 12-23-2008, 11:26 PM
LS1-450's Avatar
blanco,
Didn't you say that there was some new product information that you had coming regarding spark resistance; in the advanced section, about a Month ago? Do you have it? Thanks
Old 12-24-2008, 11:50 AM
ordered thanks for the smokin deal
Old 01-04-2009, 11:21 PM
what about gap, what are you guys running, sorry for the stupid questions this is my first ls1
Old 01-04-2009, 11:38 PM
jrenfrew0606's Avatar
i run my tr6s at a .55 gap
alot of guys run them at a .60 i think tho
Old 01-05-2009, 01:35 AM
LS1nut377's Avatar
.55 on tr55's
