Ms3 vs Ms4 Dyno charts
Old 12-30-2008, 04:07 PM
1'low92's Avatar
Default Ms3 vs Ms4 Dyno charts
Can someone post up a dyno chart of an Ms3 cam and one from an Ms4... Trying to see the big difference....thanks
Old 01-26-2009, 01:10 PM
maggiemike's Avatar
big response aye?
Old 01-26-2009, 04:59 PM
stealth355tpi's Avatar
MS3
Old 01-26-2009, 08:07 PM
blown03mustang's Avatar
wow the numbers above are very impressive....that cam doesnt look as peaky as people make it out to be
Old 01-26-2009, 09:15 PM
1'low92's Avatar
damm i thought this thread had died lol thanks for that graph the car made good numbers..
Old 01-26-2009, 10:10 PM
SweetS10V8's Avatar
How do you plan on making a desicion from a dyno graph if it wasnt done on the same car, same day, and on the same dyno?
Old 01-27-2009, 06:20 AM
maggiemike's Avatar
i don't know about the OP, but I was more interested in the curve than the numbers themselves
Old 01-27-2009, 09:39 AM
numbers above were before the 12bolt and ported TB so i lost a couple hp but then gained some. probably still right in the same ballpark.
Old 01-27-2009, 10:12 AM
TXZ0603's Avatar
Diferent dyno
Old 01-27-2009, 11:01 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
I will look through my engine dyno testing data. The MS4 made power a little bit earlier & made a few peak hp over the MS3.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 01-27-2009, 11:40 AM
teke184's Avatar
hmm...according to the Houston Perf. graph...my poorly tuned 233 cam made +25 hp at 4000rpm than that cam.
interesting
Old 01-27-2009, 07:00 PM
1'low92's Avatar
i made my decision already went with the ms3 but i was mostly interested in the power curve.......
Old 01-27-2009, 08:05 PM
slowandrichws6's Avatar
my ms4 i used to run made 418 untuned with full bolt ons and that was on a dynojet
Quick Reply: Ms3 vs Ms4 Dyno charts
