Low HP for 01 SS?
Old 12-30-2008, 06:55 PM
mtuggle86's Avatar
Default Low HP for 01 SS?
hey guy just wondering about my cars power from reading on here it seems like its a lil low on power not much just a little bit mods are in my sig what do you guys think Im sure the high temp of the dyno run dropped some off
Old 12-30-2008, 07:05 PM
02BLKWS6MD's Avatar
yeah that seems low. what kind of dyno? was that with cutouts open?
Old 12-30-2008, 07:06 PM
Mean87SS's Avatar
What kind of dyno? whats the A/F? Timing??
Old 12-30-2008, 07:09 PM
SOMbitch's Avatar
Sounds about right. The 3.73's and heavy wheels are costing you some power....
Old 12-30-2008, 07:20 PM
mtuggle86's Avatar
the heavy wheels where not on the car the dyno was done by the pre owner so I dont know if the cutouts where open the dyno was a Dynojet 424x and the a/f ratio is around 13.1 to 1 the first run was only 284hp at around 13.9 to one then he richened it up and it ran a 297 Could it be the high temp of the dyno run 88 degrees?
Old 12-31-2008, 01:58 AM
bigfatls6's Avatar
My a4 car made 330 with pacesetter long tubes, LM1 catback and texasspeed catted y pipe and slp lid. If I were you I would ditch the K&N FIPK kit and get a lid. That would probably be worth a few horse power and then get a better catback or open the cutout.
Old 12-31-2008, 09:36 AM
03Sssnake's Avatar
That does seem a tad off, even with the gears, but I would not put much stock in dyno numbers, there is too much variance. I got caught up in the dyno craze when I had my 03 cobra . I have yet to visit the dyno with this car, instead I just go to the track to see if my ETs are better with new parts As for tuning, I had the car road tuned by local guy, it would probably be beneficial at this point to eventually head over to dyno to make final adjustments to the tune.
Old 12-31-2008, 09:53 AM
99Hawk6spd's Avatar
I have a 99 firehawk with dyno'd with 103k miles. It put out 303rwhp and 328rwtq. That was completely stock M6.
Edit:
And it was around 100 degrees that day.
Old 12-31-2008, 10:06 AM
SOMbitch's Avatar
i still think you are about right when you consider your only mods are the FIPK and cutout. The cut out won't help all that much on factory manis and the 373's prolly negated what you picked up there. A4's usually dyno 290-310 stock so you are right there. Don't sweat it your in the right ballpark IMHO
(Qoute99Hawk6sp)
^^^subtract 10hp for his M6 and he's right there with you!!!
Old 12-31-2008, 11:16 AM
streetassasin's Avatar
^ OP has a M6
Old 12-31-2008, 11:22 AM
DaveX's Avatar
I wouldn't get to hung up on dyno numbers. Dyno = tuning tool. Take it to the track and see what kind of times you can get with it. Mid to low 13's is what I would expect.
Old 12-31-2008, 12:26 PM
mtuggle86's Avatar
mines an m6 im not to worried about it Im just wondering if somthing could be a little off in my car Ive noticed a very small misfire at idle and its just every few seconds just a very small stumble it fells like is this common? driveing or with a load on it goes away also somtimes when I Rev my car up its like it gets suck and the idle comes down very slowly almost like It hangs up for a second its my first ls1 car so Im not sure if these are common things these engines do or what its not throwing any codes thx for any help guys
also I believe the gears where not installed when they dynoed the car
Old 12-31-2008, 12:33 PM
CARTEK Racing
WS6TransAm01's Avatar
That is a little low...
I made 313rwhp and 328tq with only an SLP Loud Mouth cat-back... IT was late spring, so it must have been about 75F in the place whent he car was dyno'd
How many miles on the car? I know some '01s had piston ring issues. Maybe your motor is leaking down?
Old 12-31-2008, 01:04 PM
mtuggle86's Avatar
45k miles when it was on the dyno I can see it having much compression loss at those low miles but who knows the cars oil was change every 3k miles from my paper work
Old 01-01-2009, 07:06 AM
99Ls1fever's Avatar
How high did you winde the engine up to 5,900? I made max power on a stock LS1 at 6,500 rpms. If you are cutting it short then your dyno numbers will be lower.
Old 01-01-2009, 10:35 AM
DRAGONLOVER's Avatar
I only dynoed at 300 RWHP, and my tuner did it with the converter unlocked, so that would make a difference. I still do mid 12's in the 1/4, so I'd be more concerned with your times than your dyno numbers.
Old 01-01-2009, 11:05 PM
mtuggle86's Avatar
The dyno sheet says sae 1.02 Ive heard the sae hp is lower then the other kinds of dyno ratings could that play a role im also does the 1.02 mean its corrected hp?
