View Poll Results: what heads/ or change cam with heads
AFR 225's
25.58%
Trick flow 215"s
48.84%
patriot 5.3 ls6 heads
9.30%
texas speed stage 2.5
18.60%
Multiple Choice Poll. Voters: 43. You may not vote on this poll
heads cam need good advice
Old 01-01-2009, 02:51 PM
02'z28's Avatar
Default heads cam need good advice
ok i have posted on here b4 and asked about the same thing. ill try agin
i have a 2002 camaro m6. as of now i have a cam only car (springs pushrods all that good stuff also) next im looking into heads what heads should i run for best hp with a Tv 3 cam? or i have been told to change cam and so i can maximize hp with the heads
Old 01-01-2009, 03:39 PM
stoverz28's Avatar
Do some research man, theres lots of easy to find info out there on all these heads.
deuce_454's Avatar
TEA makes a good head in between the low buck patriot/TSP and high end FT/AFR... i would recomend the TEA stg 2, LS6 head,, great medium lift numbers, and 320 cfm in the high lift end
Old 01-01-2009, 03:41 PM
02'z28's Avatar
my lift on the cam is .643 forgot to put that in here. thats why ppl tell me to change cams but i really like it
teke184's Avatar
if you have the coin.....the TFS are pretty hard to beat.
great flow
improved valve angle for more clearance
great runner size for power down low without sacraficing power up top
downside is you have to buy roller rockers along with them.
Old 01-01-2009, 03:48 PM
02'z28's Avatar
sorry i dont know much about motors why would i need roller rockers with only those heads
Old 01-01-2009, 04:03 PM
ZMONSTER!'s Avatar
technically you dont, you can run RR's with TFS heads, but why? Really its only another 400 bucks but it will ensure perfect valve train geometry and reduce wear. I have seen where TFS says you can run stock rockers, but advises against it so strongly that they dont even consider it an option.
Old 01-01-2009, 07:12 PM
02'z28's Avatar
thanks had no idea i needed them would it be a good idea to get roller rockers with any head? sorry i really dont know
Old 01-01-2009, 07:17 PM
vsocks1's Avatar
They are needed specifically with TFS to get proper valvetrain geometry. Isn't as much a necessity with the other heads.
Old 01-01-2009, 07:45 PM
ZMONSTER!'s Avatar
yes roller rockers are a good idea with any aftermarket head. I believe the determining factor as far as valve train wear goes is the bronze valve guides.
Old 01-03-2009, 08:19 PM
02'z28's Avatar
thanks looks like trick flows are winning
Old 01-03-2009, 09:36 PM
1969mach1's Avatar
AFR 205's
here is why
https://ls1tech.com/forums/generatio...heads-cam.html
Old 01-03-2009, 11:14 PM
caviness's Avatar
just search the dyno section for 346ci and pick the power you want,atleast 10 different combo's in their with all heads and cams.myself i like tfs and afr and going to get tfs 225's for my engine.
Old 01-06-2009, 10:08 AM
LS1Tech Sponsor
TrickFlowTech's Avatar
False statement.
__________________
http://www.trickflow.com/emain.asp
Click Above for Product Information
Old 01-06-2009, 10:09 AM
LS1Tech Sponsor
True and that is with any head.
__________________
Old 01-06-2009, 02:15 PM
eamador11's Avatar
Originally Posted by TrickFlowTech
False statement.
huh? you can run stock rockers now with TFS 215s?
Old 01-18-2009, 11:06 AM
02'z28's Avatar
lol so what is really true?
Old 01-18-2009, 12:26 PM
Silver98vette's Avatar
Thumbs up Afr
Love my AFR 205 heads
T'
Old 01-18-2009, 02:13 PM
vettenuts's Avatar
No, I think what "TrickFlow" was stating as false is the statement that only Trick Flow heads should be run with roller rockers.
Old 01-19-2009, 09:44 AM
LS1Tech Sponsor
Correct.
We will only warranty our heads if you are using roller rockers. It is not due to geometry as some seem to think. On the larger high lift cams using a stock rocker you will get guide wear on bronze guides and you will get valve tip scrubbing. This is just not on our heads!!!! We have tested many aftermarket and factory heads and they have all done it.
__________________
