Best Cylinder Heads
Old 03-28-2009, 07:04 PM
mormjatt's Avatar
Default Best Cylinder Heads
I have a 2000 z28 with a LS1. I want to know what are the best cylinder heads for these cars.
Old 03-28-2009, 08:37 PM
sroach20's Avatar
you want best budget heads, or money is no object heads.
Old 03-28-2009, 08:55 PM
djsanchez2's Avatar
Low budget = Stock 243 heads
No budget = TEA, AFR, etc. (depending on specific use)
Old 03-28-2009, 10:44 PM
redtail2426's Avatar
how much do you want to spend,prices range from 1000 to almost 3k for a set of nice heads.
Old 03-28-2009, 10:52 PM
sroach20's Avatar
you can go allot higher than $3k.
Old 03-29-2009, 08:31 AM
True,i am just not sure about how much the best heads are.So that raises a ??.What is the most expensive cylinder head for the ls1.I am curious.I know there is a 4 valve head,but whats the most expensive 2 valve head.
Old 03-29-2009, 11:31 AM
1bdtrk's Avatar
Location: Currently, Zormat, Afghanistan....Home staion, FT. Richardson, Alaska
probably a dart worked over by a reputable builder such as bret bauer. Maybe not the MOST EXPENSIVE but pricey depending on your budget, but worth the money.
speaking of bret, anyone got his number? site is down and I need to chat with that guy.
Old 03-29-2009, 02:23 PM
SOMbitch's Avatar
PM sent, hope it helps.
Old 03-29-2009, 02:49 PM
eamador11's Avatar
LMAO
This thread is similar to this:
https://ls1tech.com/forums/generatio...ket-heads.html
Old 03-30-2009, 11:28 AM
8 second mod
Noyzee's Avatar
my trickflows done by TEA where outstanding!!! my new ones will be there new 6 bolt heads. A++ for TEA
Old 03-30-2009, 11:34 AM
thebassbass's Avatar
i am not sure but might be et canted heads there site said $7000
Old 03-30-2009, 11:41 AM
99blancoSS's Avatar
All Pro should be considered as well, IIRC they have a small bore coming out. talk to Richard at WCCH for info about it but you have a few options these days. AFR, TFS, PRC (new castings), ET, Dart (T4P), Edelbrock. That I can think of off the top of my head
