Trying to decide on a cam, or will I need to go custom?
I will admit I've never done a cam swap before however there's a first time for everything, and I don't want to have to do this twice to get what I want from my motor.
I have a 2002 Corvette coupe. I will have the following mods installed at the time of the cam swap...
-LS6 Heads (probably will be installing them at the same time as the cam - Probably will be PORTED)
-LG Street Longtube headers
-Z06 exhuast
-Vararam intake
-T-stat
Now obviously I plan on doing gaskets, valve springs, studs (like I said heads at the same time), and a proper dyno/street tune as well.
However as it says in the cam guide "be brutally honest" about what you want from your cam and how you intend to use it...
Well I want to make about 425whp with the cam and have not-too choppy idle and most importantly I don't want it to buck at all while driving in 6th gear above 55mph - I have stock gearing on my C5 keep that in mind as I drive the car every day (it is my primary vehicle). I want to to be as close to STOCK (while cruising) as possible.
With that said, what off-the-shelf cam would you guys recommend? Or should I look into a custom one?
*edit* After doing some research I'm thinking about Vengeance Racing's VRX4 cam...
http://www.vengeancerd.com/cart/products.php?cat=108
-Z06 exhuast
-Vararam intake
-T-stat
I think this package was built for you:
http://www.thunderracing.com/catalog...vid=7&pcid=289
It's the CheaTR cam and head package from Thunder Racing. It's designed to give you ~400hp to the wheels and sound totally stock.
Stock however I wanna find out how much it'd be to port them, I might depending on cost.
LS1Tech Premium Sponsor
We typically charge $650 for cnc work and reassembly. You need to run a search in the dyno section on ported LS6 heads. I think you'll find the Precision Race Components line of LS6 heads are consistanly outperforming the competition.
If you'd like a custom camshaft give us a call, while I think the 224R camshaft would be a great camshaft in your application, we can also help spec something custom for you
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
