UMI TB vs Nicki William TB (90mm)
Good day gentlemen,
I looking for TB with intake manifold ( FAST 90mm )
I have to choices UMI and william , from your experiance .. which one do you prefer ?
UMI
Nicki William
I'm worry anout sticking
UMI
Nicki William
You can't go wrong with either one I'm sure, but I have the UMI also. No sticking and a high quality piece. The placement of the pin where the cruise control cable snaps onto tends to stretch it to it's limit possibly holding the throttle open if not corrected. Basically, you just have to remove the bracket from the TB and modify it a little so it rotates counterclockwise a few degrees. No big deal. This pic shows the cruise cable stretched before the fix.
you just take a drill and drill the whole of the cruise arm out a little to do away with the key.... then adjust it to where you need it and tighten it back... it sounds like a lot of work but its not....... I love the TB cant go wrong with a UMI....
