slower than before , cam installed
Old 04-28-2009, 06:30 PM
PONTIAC SLP's Avatar
Default slower than before , cam installed
Hi , my buddy have 2000 M6 camaro , the camaro was full exhaust and LS6 manifold then he installed patriot springs 650Lift and 224 224 .581 .581 112LSA , the problem now : the car is very slow , when he was with the stock cam it pulled harder than now at the street , what is the problem ? is the problem from the cam ? or what ?
thanks, Mohammed.
Old 04-28-2009, 06:33 PM
Ramairbird's Avatar
Was the cam timing set correctly? Was the car tuned after the install?
Old 04-28-2009, 06:40 PM
yep the cam timing has done corectly , no until now we did't tuned the car , i think the problem with that 650lift springs ! now he wanna replace the cam and he planning on T-rex or G5X3 , what u recommend us ?
Old 04-28-2009, 06:53 PM
nastychevelle's Avatar
definitely not the springs... if it isnt tuned thats your problem and do you have a torque convertor?
EDIT: didnt see it was a M6 my bad
Old 04-28-2009, 07:09 PM
aha i see , why torque convertor ? the car is manual not automatic , what u recommend us guys to run with ? T-rex , G5x3 or custom cam from Patrick G
Old 04-28-2009, 07:11 PM
CJohnsonZ28's Avatar
you need to get that car tuned before anything.. its not going to run right until its tuned
Old 04-28-2009, 07:15 PM
SOMbitch's Avatar
It SHOULD go faster but I wouldn't go WOT until it is tuned cause the AFR will be way off. Sounds like a tooth off to me......
Old 04-28-2009, 07:26 PM
i didnt notice it was a m6 my bad... still get it tuned it will make a world of difference
Old 04-28-2009, 07:37 PM
NP , he wanna change the cam but he don't know what he should install !
Old 04-28-2009, 07:59 PM
blkbird's Avatar
Before you go through all that again, check the dot to dot and get it tuned.
Old 04-28-2009, 08:03 PM
x2!!!
Old 04-28-2009, 08:05 PM
dot on dot very correctly
Old 04-28-2009, 08:12 PM
blkbird's Avatar
Then go get it tuned. Youd be surprised at what a good tune will do.
Old 04-28-2009, 08:13 PM
nick1ta's Avatar
WHAT ABOUT THE FREAKING TUNE! I S I T T U N E D?
holy cow!
Old 04-28-2009, 08:36 PM
goober35's Avatar
Sounds like yall got into swaping a cam before you knew all the ends and outs of a cam swap.
Old 04-28-2009, 08:38 PM
djfury05's Avatar
holy cow!
yea wow lol.. how many times can you drill something into someone's head lol
Old 04-28-2009, 08:42 PM
STEEPSS's Avatar
never. enough.
Old 04-28-2009, 09:14 PM
dub.ya.es.SICK's Avatar
how stupid is this crap going to get!?!?!?!?!!?
Old 04-28-2009, 09:34 PM
get a tune then come back if its still running slower
