New motors, how much more power once they've fully broken in, if any ??
Old 05-03-2009, 10:40 PM
allngn_c5's Avatar
Default New motors, how much more power once they've fully broken in, if any ??
Not sure if this is the correct section, but I am sure a mod can move it if I am posting here in error.
Like the title says, do newly built motors after being fully broken in make anymore power ??
I ask this question because some people make such a big deal about "and these dyno numbers are with only 29 miles on the car" and other comments like "she'll make even more once she loosens up" . Does anyone have a graph for there newly built motor, and then another graph 2000+ miles later showing a gain, loss, or same output ??
Thanks in advance.
Old 05-03-2009, 11:11 PM
LSX Mechanic
Damian's Avatar
Yes, engines make more power (assuming they're being maintained properly) as life goes on.
I've done a couple of 347's just as of late that have made 10-18 more rwhp with 2-3,000 miles compared to what they did with 500 miles. Nothing else was changed other than mileage.
Moving this to the proper section for you.
Old 05-03-2009, 11:14 PM
allngn_c5's Avatar
Thanks D !!!
Old 05-03-2009, 11:45 PM
BlueBird346's Avatar
I read about a G8, on this site i think, that made a noticeable increase in power after being broken in.
Old 05-04-2009, 12:06 AM
RoDan's Avatar
depends on how you broke it in, lol
Old 05-04-2009, 12:11 AM
LSX Mechanic
Damian's Avatar
This is also very true.
Old 05-04-2009, 07:00 AM
allngn_c5's Avatar
Thanks for all the replies everybody.
Still looking for graphs though. I'd really like to see some graphs that were from a new FORGED motor, or even new crate motor that was heat cycled several times, a couple oil changes, and tuned then dyno'd for a baseline number. Then that same motor with a couple thousand on the clock that was redyno'd. What were the new numbers ??
Anyone ??
Old 05-04-2009, 07:01 AM
allngn_c5's Avatar
Assuming proper break in. lol
Old 05-04-2009, 10:00 AM
LSX Mechanic
Damian's Avatar
/\ - What he means by that is beating the **** out of it.
I know guys who came out of the dealership sideways with 3 miles on the clock of their 01-02 F-bodies, and 10,000 miles later the cars were running 12's bone stock. Then I've seen people who've babied their car for 20,000-30,000, and can't even get out of the 13.50's.
On aftermarket motors, I do recommend giving at least a 500 mile break in period to let everything seat. After that, drive that damn thing like you stole it.
Old 05-04-2009, 10:09 AM
allngn_c5's Avatar
I've gotten on it, but I let it run until she's completely warmed up. I did exactly as LGM said on the drive home, keep the rpms varied and change the oil immediately before I start driving it regularly. I'd assume after the 1200 mile drive home and pre break in that LGM did, and additional several hundred miles I've put on her back and forth to work on the weekends I'd assume she is good.
Looking fwd to seeing what she puts down next time I strap her to the dyno.
Old 05-04-2009, 10:10 AM
SS Enforcer's Avatar
I fried the rears coming out of a dealers after getting a new LS1 fitted a few years ago, even banged the limiter . The dealer wasn't impressed but the motor was a strong one.
My VE/G8 was the same flogged it from day one and it ran a 13.5 bog stock in the heat and for a 4000 +lb car that was pretty good.
cheers
blu1's Avatar
Do you plan to dyno at a local shop in MI? I would be VERY curious to see the numbers from a different shop.
allngn_c5's Avatar
Was also told to use 15w50 mobil 1. That stuff will definately stand up to the heat and whatever else is thrown at it.
Old 05-04-2009, 10:14 AM
allngn_c5's Avatar
I had already done that previousl with the 346 h/c setup and considering it was STD vs SAE, the numbers here in std were higher as expected and I would consider that to be on par.
To answer your question, NO, I have another dyno that will be doing a baseline on the car before the new heads, headers and cam go in.
Anyone in the market for some afr 205's 58.x cc with new 921's and valve seals ??? Includes arp bolts and shipping 2000 obo
Old 05-04-2009, 12:00 PM
teke184's Avatar
would those heads clear a 233/233 .589" 112 cam??
mmm...tempting!!!
Old 05-04-2009, 12:37 PM
allngn_c5's Avatar
teke184 pm sent
Old 05-04-2009, 03:09 PM
99Ls1fever's Avatar
Good Thread Subscribing...
Old 05-04-2009, 08:38 PM
allngn_c5's Avatar
Thanks a lot man.
I was hoping to get some comments from some of the sponsors on here to share there experiences on motors they built, tuned, dyno'd and re dyno'd a couple thousand miles later.
Old 05-08-2009, 10:52 AM
allngn_c5's Avatar
mmm...tempting!!!
I sent you a pm and never heard back from ya bro. But yes it should with a .056 gasket. Shouldn't have to flycut.
Old 05-08-2009, 10:54 AM
allngn_c5's Avatar
Calling Sponsors could you please share your experiences with new motors loosening up. Slowhawk, and Edcmat-1
