1.550" springs on Ls6 heads?
I'd say "no". I worked on a set of ported 243's that had been cut for 1.4x springs and the edge of the spring pocket went through the roof of a couple of the intake ports. Had to do a little epoxy work to fix them.
is there away on earth to run solid camshaft on stock heads then?
the custom cam fo my application recomended by comp cams
needs 210 on the seat and 523 open
can I use stronger shims under the springs to spread the load
I have 2 sets of shaft mount rockers jesel and patriot will they still need to be cleared for springs larger than 1.3
Dunno how accomodating the heads will be though, port walls on some ported heads are pretty thin so you run the risk of the spring pushing thru the head...if you're looking to go that radical...why use OEM heads
Moderator
You can run that large of a spring, it's been done successfully plenty of times, but it takes some work. Unless you already have your portwork to run over 8000rpm, it's probably not worth it with the aftermarket heads available.
Which naturally begs the question, why OEM heads?
Did you talk to Comp about removing mass from the system? There are two ways to go, more spring or less mass. Also, for stock rockers, LPE makes a steel rocker brace that replaces the OEM aluminum that will help provide some additional support to the stock rocker. If you are LS6 stock size valves, the LS6 valves will help along with Ti retainers and a good beehive spring. Although, you don't give cam specifications only "radical".
cam specs as follow
Lift with 1.7 rocker arms .644/.644
Duration @.050: 231/231
LSA:115
Advance ground into cam:4
as comp said "This is a hydraulic roller cam, but you will need to run solid roller lifters on the cam"
this is for a twin turbo 347
why OEM heads? these heads been worked by Wegner motorsports they are the same heads they used to use in there NASCAR engine but I bought bare.
the blans back then was to build N/A engine then it changed to twin garrett gt35s
I have 2 sets of adjustable shaft mount rockers to use I have Jesel & Patriot and going to use SS valves stock sive thu
I have alot of LSX parts in my shop and I'm trying to make them work for me
LSA:115
why OEM heads?
Moderator
cam specs as follow
LSA:115
LSA:115
No offense, but that doesn't look like much of a radical cam at all. It sure doesn't look like enough to support a 347ci LSx to 8000rpm, either. If you're going with twins, why do you feel the need to run so much RPM? Honestly, you should be able to get away with a hydraulic roller just fine, turn less rpm, and save some headache.
Originally Posted by COMPCAMS
The cam I am about to suggest for your engine is a very aggressive cam. This is a hydraulic roller cam, but you will need to run solid roller lifters on the cam. I would go with this custom grind number 2128/2128 HR 115+4.
thanks for the help
