LS1 Camshaft Installation Tool
Old 05-09-2009, 04:58 PM
bad98camaro's Avatar
Exclamation LS1 Camshaft Installation Tool
were can i get a LS1 camshaft installation tool to keeps the lifters from falling. i order them from thunder racing but its been 3 weels and no tools. i need it asap
Old 05-09-2009, 05:16 PM
Hi-Po's Avatar
Home Depot.
And its not known as a cam shaft install tool there either. They call it 5/16 wooden dowel rods for 2 bucks. Im thinking about making my own buisness and selling them for 105 bucks.
Old 05-09-2009, 05:23 PM
Have u used them
Old 05-09-2009, 06:00 PM
Hi-Po's Avatar
Originally Posted by bad98camaro
Have u used them
What the Home Depot non *** raping install tool?
Yes, and it worked fine.
Old 05-09-2009, 06:03 PM
did u have to cut them or anything
Old 05-09-2009, 06:27 PM
gillbot's Avatar
Originally Posted by Hi-Po
Home Depot.
I won't use wood, they can get shaving in the block or break. you can get solid dowels but they didn't fit well when I tried those. The best thing i've found to use is brake line.
Old 05-09-2009, 06:50 PM
Hi-Po's Avatar
I thought about the wood thing. When I used them they felt likke they barely touched anything going in or out. I changed my oil 80 miles after cam install anyway
Point being, you dont have to spend 100+ dollars on such a easy tool to make. Plus, when the hell do these people recieve thier products they paid for? Seems people are always waiting for this tool. BS
Old 05-09-2009, 07:10 PM
what size of brake lines did u use. do i have to lower the oil pan down 1/2in when i do the oil pump.
Old 05-09-2009, 07:26 PM
Hi-Po's Avatar
Yes, if you are changing the oil pump/timing chain, you will have to drop it as much as you can. Its tight getting the oil pump pick up tube bolts back in, but it can be done. Remember, when re-installing the pick up tube, do NOT force it. Do not get the bolt started and use the bolt to bring the tube in. You need to hold the tube up with your fingers and then tighten the bolt. Pinching the oil pump pick up o-ring is not fun.
Edit - 10mm racthet wrench will be your freind.
Old 05-09-2009, 08:13 PM
89tang's Avatar
I've used the dowel rods on 5 cam installs and never had a problem with them breaking or leaving wood shaving's behind. They work perfect plus they cost like $2.
Old 05-09-2009, 08:52 PM
tonyss96dcm's Avatar
I just did a cam swap last night using the wooden dowel rods. Used the new cam to cut them to size. Drivers side slid right in, passengers side had to work it in but didnt force it in. Spent a whopin 86 cents!
Old 05-09-2009, 09:29 PM
05 GSXR 1XXX's Avatar
yea i read using these famous tools, doesnt make sense to buy these if a local hardware store carries these for dirt cheap...
im kinda on edge using wood aswell, why not just buy the metal ones for a few bucks more? safer insurance
Old 05-09-2009, 09:37 PM
eseibel67's Avatar
I was skeptical about sticking wood in my engine when I first heard about it.
But after actually doing it, it's no problem and I will always use the wooden dowels to hold up the lifters.
Old 05-09-2009, 11:11 PM
Randy WS6's Avatar
I took two steel 5/16" rods and took a grinder and ground down one side flat then welded me a 2" peace at the end for handles and they slid right in .
Old 05-10-2009, 12:01 AM
taws6m6's Avatar
I'd use the wood and spend the rest on blow
Old 05-10-2009, 12:52 AM
thanks alot for ur help
Old 05-10-2009, 09:51 AM
Steve Gunn's Avatar
and a cheap hooker...
Quick Reply: LS1 Camshaft Installation Tool
