for all you high hp guys
Old 05-11-2009, 06:42 AM
Shawn @ VA Speed's Avatar
Default for all you high hp guys
https://ls1tech.com/forums/new-produ...rt-system.html
Old 05-11-2009, 09:00 AM
allngn_c5's Avatar
So how much does this support system add to the blocks capabilities to handle the power being made ?? (with support the block is safe another 400 hp ?? just an example )
Old 05-11-2009, 10:09 AM
blueshark123's Avatar
yeah that^ up to what hp range has it been tested to?
Old 05-11-2009, 12:06 PM
Fireball's Avatar
the motor in the picture is gonna make north of 2000 hp.
Old 05-11-2009, 12:23 PM
IFRYRCE's Avatar
The 07+ blocks had 20% increased bulkhead strength, and the 08+ blocks got another 20% increase for 40% total according to GM (per PHR's issue with all the LS9 info). So would it be safe to say that this would strengthen a Gen III block to these new 08+ levels?
Old 05-11-2009, 01:25 PM
7 Second Club
Phil99vette's Avatar
Better question is which block are you trying to use and how much horsepower are you trying to make.
Old 05-11-2009, 02:31 PM
LS1TECH Sponsor
floormatman's Avatar
Would like to see this on more cars
Old 05-11-2009, 07:40 PM
it will make it strong enough that the head clamping capability and cylider sleeves will be the weakest points in the engine
from our modeling it will strengthen the main alot more than that
