what cam makes the most power?pleasse help!
Old 11-06-2003, 03:14 AM
badbluess's Avatar
Default what cam makes the most power?pleasse help!
just need to know what cam makes the most power,with a semi big ci. motor with nos?its just going to be a strip only car,so it will not be driven on the street.please help by friday.
Old 11-06-2003, 07:46 AM
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
just need to know what cam makes the most power (thats a rather general question),
with a semi big ci. motor with nos?(how big, how much gas)
A few important questions.
What kind of bottom end? i.e.
What CR?
What rods/pistons
What crank?
What kind of induction
What heads?
What intake?
What TB?
What kind of drivetrain?
M6, A4 or A3
What clutch or what converter?
What kind of rear?
What gear?
Old 11-06-2003, 10:20 AM
Colonel's Avatar
Solid lift or hydraulic?
How many RPMs to you care to spin it?
Info please!
Old 11-06-2003, 11:03 AM
cyphur's Avatar
Badbluess, they are askin for more info for a reason. Too many variables right now, as J-Rod pointed out. Help us out man.
Old 11-06-2003, 01:52 PM
badbluess's Avatar
sorry i was half asleep when i wrote that.Its a 6.0 block,billit rods,wiesco piston with valve relief,with a billit crank,and its going to be hydraulic for now,ls1 heads now but down the road im going to a ls6 head.
Old 11-06-2003, 01:56 PM
HOSS99's Avatar
Are the LS1 heads stock or ported? Do you know what they flow?
Old 11-06-2003, 02:11 PM
badbluess's Avatar
the ls1 heads im using now are ported and flow well over 300cfm.
Old 11-06-2003, 02:22 PM
The Juggernaut's Avatar
G5x-4.
Old 11-06-2003, 02:39 PM
badbluess's Avatar
Originally Posted by 01-Z
G5x-4.
whats the specs on that cam?
